Go to Post First, corndogs and now cowbells... when will you make the pain stop, Frank?!?!?! - barn34 [more]
Unread 23-01-2008, 18:22
CollmandosGrl CollmandosGrl is offline
None #1466
CollmandosGrl has a spectacular aura aboutCollmandosGrl has a spectacular aura aboutCollmandosGrl has a spectacular aura about
Is Carbon Fiber allowed?
Is carbon fiber an allowed material for use on robots? Thanks!
Unread 23-01-2008, 18:23
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
Re: Is Carbon Fiber allowed?
yes but make sure you dont exceed the cost limit.
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 23-01-2008, 18:26
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
The material would be allowed as long as it is under $400 per unit that you purchase/get donated. If it is donated it also has to be available to other teams to purchase from that vendor in the quantities you get it in.
None #1466
How about Fiberglass?
Thanks :-*
Unread 23-01-2008, 18:28
Thanks :-*
Same response as for carbon fiber.
I know that one of the teams on Einstein last year used a pultruded fiberglass arm. No problems with inspection.
Unread 23-01-2008, 19:03
ADZDEBLICK's Avatar
ADZDEBLICK ADZDEBLICK is offline
AKA: Andrew Zdeblick
FRC #0195 (Cyber Knights)
ADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to behold
Send a message via AIM to ADZDEBLICK
Our team found a company that is providing us with uni-directional carbon fiber sheets about 4'x2' with the resin already in it. you can form it by heating it up to about 300 degrees and then bending it around a mold. They gave us an estimated cost of about $100 a sheet.
Unread 23-01-2008, 23:05
esisso esisso is offline
AKA: Eitan
FRC #1242 (Team Smiley)
esisso will become famous soon enough
Send a message via AIM to esisso Send a message via MSN to esisso
does this company wanna donate some of those to our team as well? lol
Unread 23-01-2008, 23:13
caraddicted101 caraddicted101 is offline
caraddicted101 has a spectacular aura aboutcaraddicted101 has a spectacular aura about
In regards to using carbon fiber, I would recommend to go over the application that it would be for throughly and make sure that you really want to use the carbon fiber. In the past my team used it for our chassis 2 years in a row and i was not pleased with it either of the times. YES, it is light when you buy it, but as it is known for it's strength, I know it for being a pain when bolting things to it. If you do not lay epoxy down or put a big flange washer and you just bolt something to it the honey comb will compress and then you loose all the integrity in that area. If it up to your team to use it, but as a veteran in using it i would not recommend it at all. Too much work and money. However, there are good uses for it and if used correctly it is a great part.
--hope this helps
Unread 23-01-2008, 23:22
Martino's Avatar
Martino Martino is offline
FRC #1825
Martino is on a distinguished road
Send a message via AIM to Martino Send a message via MSN to Martino
Thanks :-*
last year my team used a fiberglass arm and it did the job... if you have someone on your team that knows how to use it its not to bad to work with. what we did for bolting things to it is we put wood in where we needed to put something on it...
Unread 23-01-2008, 23:28
Gdeaver Gdeaver is online now
FRC #1640
Composites are allowed as long as they meet the cost and availability requirements. Fabricating with them requies different methods then metal. Sounds like the company is offering you some high temp prepeg material. If your team doesn't have someone who is experienced with laying up prepegs, You may not want to try to master these skills this late in the build season. This would make a good off season project.
Carbon Fiber Jeff K. Technical Discussion 29 19-10-2006 23:05
Carbon fiber edomus General Forum 4 19-02-2004 19:02
Q&A Discuss: Carbon Fiber CD47-Bot Extra Discussion 1 04-02-2003 12:15
Carbon Fiber kbmeister Kit & Additional Hardware 6 07-01-2003 12:24
Carbon fiber? Munchausen Technical Discussion 1 25-01-2002 21:20
