Go to Post You never really graduate out of FIRST.... - Gnomegirl [more]
Unread 23-01-2008, 20:02
sparrowkc sparrowkc is offline
AKA: Mark
FRC #1986 (Team Titanium)
sparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to behold
9 pin cable from radio to RC
Do I have to use the supplied cable, or can I make my own shorter more flexible cable out of flat cable?
<R67> ...and 9-pin cables shall not be tampered with, modified, or adjusted in any way.
<R71> Ribbon cable ... may be used to connect signal lines to the 9 pin ports on the Robot Controller.
The space I have to mount the RC in is kind of funky, and If I have to use the bulky supplied cable, our RC is going to have to be mounted vertically or something...
Unread 23-01-2008, 21:03
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: 9 pin cable from radio to RC
You will probably want to check out this Q&A system answer, which addresses how the radio modem must be connected to the RC.
-dave
Innovation First acquires Vex from Radio Shack Brandon Martus General Forum 58 20-04-2006 17:32
VEX Kits for Sale from Radio Shack fowlerm FIRST Tech Challenge 8 12-04-2005 14:07
Radio Cable Burning!!! Cadetdan Electrical 10 15-02-2004 09:46
Cable Pin outs Wetzel Electrical 8 10-01-2004 13:50
using set screw or dowel pin/pin to hold on drill motor coupler thinggy Travis Covington Motors 1 04-02-2002 03:02
