Go to Post You're part of what makes FIRST so special. - Matt Krass [more]
Unread 23-01-2008, 19:47
duck1370 duck1370 is offline
AKA: duck
FRC #1370 (Thermogenesis)
duck1370 is on a distinguished road
Worm Gear?
We were wondering where we could purchase around 35" long worm gears? The diameter of the shaft isn't too big of an issue as long as it can take the strain of moving upwards of 75 pounds horizontally. We require two of said worm gears with soem sort of female attachment to make use of the gear.
Basically we are looking for a longer version of the worm gear and female attachment that came in the kit of parts...
Any help would be appreciated
Unread 23-01-2008, 19:56
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Worm Gear?
I believe what you are looking for is a lead screw. Search McMaster.com for lead screws and you should find what you are looking for. Unfortunately, I can't recall the pitch, etc. of the screw in the kit. Anyone have these measurements?
Unread 23-01-2008, 19:57
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
Re: Worm Gear?
Your looking for a lead screw.
Last year we used one from Kerk Motion to lift our arm assembly.
They work very well, and can take the regular abuse of the FRC competition enviroment. After having our cart assembly on our rail slider knocked off, the lead screw took the load, and still to this day is moving it up and down, after some gentle persuation using the lathe
Unread 23-01-2008, 20:15
AKA: duck
Re: Worm Gear?
Thanks for correcting my terminology... by searching for lead screws we were able to find lead screws more suited to our needs. However the lengths of these lead screws seem to be relatively short, in comparison to the approximately 35" lead screws that we are in need of...
Unread 23-01-2008, 20:20
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Worm Gear?
Look at McMaster page 1079. They have nuts for them too.
Unread 23-01-2008, 20:21
Joe G.'s Avatar
AKA: Josepher
Re: Worm Gear?
McMaster-Carr has 6 foot lengths. I am not sure how what diamiter, turns per inch, etc. you need, but here is a 3/8" diamiter, 6 foot screw: part# 98940A006
Edit: here is the matching nut
part# 6350K35
Unread 23-01-2008, 20:24
AKA: duck
Re: Worm Gear?
thank you very much, this was exactly what we needed
Unread 23-01-2008, 20:26
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Worm Gear?
You'll also find appropriate types of screw mechanisms as "Acme threaded rod" or "ball screws".
Worm gears sets are intended to remain in a fixed position with respect to each other; lead screws are designed to translate. They aren't interchangeable with lead screws, as a result.
Unread 23-01-2008, 21:01
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Worm Gear?
If cost is an issue, you can use non-precision or low-precision lead screw material. This costs up to 50% less than precision material, which can be had with accuracies better than 0.001" per foot. Even regular hardware store "all thread" threaded rod can be adequate if accuracy (less than a few thousandths) is not required.
If the price you find is OK, though, just buy it.
Don
Worm Gear Drive Rob2713g Technical Discussion 16 05-11-2008 13:03
Worm Gear Calvin_1631 Motors 11 06-03-2007 10:39
worm gear emergency ClicheCow Technical Discussion 5 21-02-2005 01:39
Worm Gear Gearbox dddriveman Technical Discussion 38 07-01-2005 14:43
Van Door Worm Gear Jim Giacchi Motors 4 16-12-2003 09:35
