Go to Post FIRST is here to inspire you, to challenge you. Part of that process is giving you a task too hard, resources too little, people too many, time too short. - ebarker [more]
Unread 23-01-2008, 13:50
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Flag holder position
Update #4 just published talks about the flag holder in one of it's sections. As a Championships Inspector, I just want to remind every team that whether or not their robot is 51 inches high, their flag holder has to be.
"<R17> Robots must use one of the two FLAGS provided at the event queuing location to display their ALLIANCE color (red or blue). The FLAG shall be held in a flag holder mounted on their ROBOT. The only acceptable flag holder is a 12 inch long piece of 1/2" (nominal) Schedule 40 PVC tube. The tube must be a single, continguous piece, capped with a commercial PVC cap cemented at the bottom end. The tube must not have any "lightening holes" or other modification other than mounting holes, paint, or other decorative finishes. The flag holder must be permanently mounted to the ROBOT such that when the ROBOT is in PLAYING CONFIGURATION and the top of the FLAG is 75 inches above the floor. As the flag pole is approximately 36 inches long, that means the top of the flag holder must be 51 inches above the floor. The region above the flag holder must be kept open and clear of obstructions so that the FLAG can be placed in the holder and displayed during the MATCH and the LAP INDICATOR is visible to the Lap Detectors (see Rule <R18>). The intent of this rule is to insure that the FLAG is as high as possible so that it may be easily seen from any side during the entire MATCH play, while fitting under the OVERPASS as the ROBOT drives around the TRACK."
(bolding mine)
Now, how many tasm forgot to design a place for their flag holder?
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 23-01-2008, 14:03
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Flag holder position
This is possibly the worst-thought out rule in '08. I agree with he intent, but I am forced to wonder if the GDC considered what happens when a 40" ball falls onto the robot from 7'. Usually the top of the flag pole will be the highest point since the maximum starting size is only 60". I also wonder if they considered what happens when a flag pole at 75" drives full-speed forward under a trackball that hangs down to below the 75" mark in hybrid mode -- it's either a flung flag or a broken flagpole.
I forsee either alot of popped trackballs or alot of broken flagpoles.
GitHub
Unread 23-01-2008, 14:09
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Don't forgot about possibly losing your lap counter since it is attached to the flag pole.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 23-01-2008, 14:16
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
I'm not sure it will be so bad. The diameter of the ball is actually a benefit to damage mitigation when it falls from the sky. Since the mass is about 7.5 lbs, the force of collision will be spread out over a larger area compared to, say, a bowling ball size. The flags will supposedly be held in place with a rubber plug, so if the flag contacts field elements, hopefully it will remain in place. If it doesn't then your laps won't get counted. Our team, for one, is taking design steps to ensure that the flag doesn't get flung out of it's holder. In years past, some teams designed with the hope that game play would get rid of the hindrance, but this year that strategy will be detrimental.
Unread 23-01-2008, 14:22
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
Originally Posted by TubaMorg View Post
I'm not sure it will be so bad. The flags will supposedly be held in place with a rubber plug
This is what I think will be the problem. In years past we always saw flags flying off the robots. This year if they are held in place and cant fly off, they may break. Hopefully they have lots of extras.
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 23-01-2008, 14:25
Al Skierkiewicz Al Skierkiewicz is online now
Don't forget that the 75" top height is a rule, not a suggestion, and that all teams must provide PWM connection near the flag holder in which to plug the lap counter device. For teams that are using a kitbot or low height chassis, you will be required to have the flag holder attached such that it meets the current rule. Please plan for it now.
Unread 23-01-2008, 15:18
AKA: Dan
Yes, as Al says, it is a rule so build accordingly. Keep in mind that the flag poles are very flexible. I would be impressed if they broke without being mechanically caught in something. They will certainly survive impacts with the ball. The weak link will be how teams implement the flag holder. Protect the lap counter and associated wiring, allow it to always be clear from above, and don't let flag impacts dislodge the flag.
Unread 23-01-2008, 18:16
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
I brought this up early on in this post. The flag forced us into a design that I think will be 1 of 3 types. I just modeled in the flag on our robot this year, and that sucker is huge! In fact, I'll say right now, that our flag (even though we tried not to) will get beat up. But hey, it's a 40" ball....
www.179swampthing.org
Unread 23-01-2008, 18:28
Gertlex's Avatar
Gertlex Gertlex is offline
Alumni and mentor
AKA: E Relson
FRC #1015 (Pi Hi Samurai)
Gertlex is on a distinguished road
For the inspection checklist, which is available along with the other documents, it's worth noting that it says 75±5" for flag height.
Unread 23-01-2008, 20:12
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Just remember that the rule, not the inspection sheet, is the ultimate authority. And the current inspection sheet is still in draft, not final, form.
-dave
Unread 23-01-2008, 20:22
Fab.Master's Avatar
Fab.Master Fab.Master is offline
FRC #0617 (Locomotives)
Fab.Master will become famous soon enough
what should be classified as "clear" above the flag/flag holder? is it directly above or around the flag within "x" inches?
Unread 23-01-2008, 20:23
Fab.Master's Avatar
This also seems like it could create problems with fast robots and a mast at 56" turning and tipping over easily
Unread 23-01-2008, 20:34
Directly above for sure. The detector is right under the overpass.
And according to <R18>,
<R18> ROBOTS must use the LAP INDICATOR provided by the field personnel during all official tournament MATCHES. The LAP INDICATOR is attached to the stopper on the flag pole. When the FLAG is placed in the flag holder, the stopper will insert into the top of the holder. To accommodate the LAP INDICATOR, the area within a minimum 180—degree horizontal arc around the top of the flag holder must be kept clear of any obstructions within a 2-inch radius. This region must be kept uncovered and visible from above. To ensure that every FINISH LINE CROSSING is properly recorded, the LAP INDICATOR must be visible to the Lap Detectors when the ROBOT passes under the OVERPASS.[...]
(emphasis mine)
Thoroughly reading the rules multiple times is a definite advantage.
Unread 25-01-2008, 22:11
Gertlex's Avatar
Alumni and mentor
AKA: E Relson
-dave
Looks like it ended up being important enough that it's now changed to ±1 inch.
Flag, Flag Holder vs Trackballs Swampdude Rules/Strategy 29 09-03-2008 09:17
pic: Ball Holder Arkorobotics Extra Discussion 4 13-01-2008 20:24
Flag holder caps. General Thunder Rules/Strategy 10 28-03-2007 15:00
pic: Mentor or Laptop Holder?? Michelle Celio Chit-Chat 7 09-05-2006 22:19
Drill Motor Holder Thunder360 Motors 4 21-01-2003 22:34
