Go to Post 1) Field reset will want to do mean things to you. They have to remove the tubes. - EricH [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
View Poll Results: omnis or casters?
omnis 27 81.82%
casters 2 6.06%
slides/ sleds 1 3.03%
does it really matter?... 3 9.09%
Voters: 33. You may not vote on this poll
Unread 01-23-2008, 08:23 PM
gondorf's Avatar
gondorf gondorf is offline
inventor/solidworks engineering spe
AKA: stephen truscott
FRC #1733 (The Polar Bots)
gondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to behold
caster wheels vs. omni wheels
i was just wondering whatpeople thought of the whole idea of having rear wheel drive and casters or omnis on the front. we tried them and withouit too much weight on them they seemto have similar drive properties in that the handling is so sensitive it is nearly impossible to attain a speed and drive straight. just wondering if there are any true advantages to either.
also since we also tried using sliders/ plastic sleds on the front to great effect ill add this too.
thanks!
Unread 01-23-2008, 08:54 PM
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: caster wheels vs. omni wheels
If you aren't going to power the Omni's I would go with some type of plastic sled or maybe a ball caster.
I would stay away from regular casters, if you've ever pushed around a shopping cart with a wheel that wants to go off on it's own you know why.
I'm sure some of the people here with more experience will be a little more helpful.
Unread 01-23-2008, 09:27 PM
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
we're having a rear wheel drive and ball casters would work but that 1/2" bump near the lane divider will give you some problems from what we found, I'd go with the omni's, we've decided to use the AM coolie doolies
Unread 01-23-2008, 10:37 PM
Nevets Amstier's Avatar
Nevets Amstier Nevets Amstier is offline
Dont Hesitate
AKA: read my username backwards
FRC #0155 (Technonuts)
Nevets Amstier is a name known to allNevets Amstier is a name known to allNevets Amstier is a name known to allNevets Amstier is a name known to allNevets Amstier is a name known to allNevets Amstier is a name known to all
If i had to choose i'd choose omnis, but with any of them you're going to be easy to pushed or nudged so that you change direction.
CLAKSON UNIVERSITY CLASS OF 2011
2012-?: Technonuts team 1552008-2011: Division By Zero team 229
2006-2007:Bobcat Robotics 177
Unread 01-23-2008, 10:45 PM
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
I think if you are going to use casters you should put them in the back and have front wheel drive. It is almost impossible to handle the robot with rear wheel drive and casters. We had casters in the back last year, and teams realized that if they hit us there we would spin out. If they hit us every once and a while they essentially took us out of the game. We eventually added a skid along with the casters to try and help the problem.
Our rookie year we had a 4 wheel drive with omnis in the front. It worked, but I was not a big fan of it because since all wheels were powered, the omnis really didnt help. Again teams found out they could hit us in the front, although it wasnt as big of an impact as the casters.
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 12-16-2006 07:40 PM
Omni Wheels edomus General Forum 6 02-06-2004 01:35 PM
Omni Wheels??? Alex Cormier General Forum 1 01-24-2004 06:00 PM
Omni Wheels! jrgrim12 Technical Discussion 5 02-04-2003 04:07 PM
We need Omni Wheels!! archiver 2001 0 06-24-2002 01:02 AM
