Go to Post Its not the event that matters - its the preparation for the event that matters! - Ken Patton [more]
Unread 15-02-2007, 15:44
almsfan21 almsfan21 is offline
FRC #1804
almsfan21 is an unknown quantity at this point
Wiring Single Solenoid
How is the single soleniod wired? Our "inventory" guy lost the instructions..
Unread 15-02-2007, 15:50
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Wiring Single Solenoid
Do you mean the gray, flat solenoids? You should have gotten connectors that plug into the solenoid. Use those to connect the solenoid to a relay.
Unread 15-02-2007, 16:06
FRC #1804
Yes, I mean the gray ones (festo), is the connector black?
Unread 15-02-2007, 21:00
http://team358.org/files/pneumatic/F...TValveAssy.pdf
Yes, the connector is black.
Unread 18-01-2008, 21:19
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
We have wired our Solinoid correctly according to these directions, however it still will not switch which hole the air comes out of? Any ideas?
Our proggrammer insists that it is coded correctly.
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
Unread 18-01-2008, 22:01
Does the light on the Spike change color when you hit the switch?
What colors do you see, orange and green?
Does the light on the solenoid turn on and off as you hit the switch?
The code should be (on the relay of your choice):
relay1_fwd = 1;
relay1_rev = 0;
and
relay1_fwd - 0;
relay1_rev = 0;
Unread 18-01-2008, 22:09
AKA: Bates
FRC #0125 (NUTRONS)
Yes the light on the spike change from orange to green.
Yes the light on the solenoid turns on and off.
I can also feel movement inside the solenoid.
I can't check the code now but will forward it to our programmer.
Any other ideas?
Unread 18-01-2008, 22:52
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
Try actuating the solenoid manually using the lever / pushbutton switch provided. If it works that way, then look at the programming.
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 18-01-2008, 22:59
AKA: Bates
FRC #0125 (NUTRONS)
It does work manually.
I guess that means it must be the programing?
Unread 18-01-2008, 23:21
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
you could also connect the leads to a battery and see if it switches state.
try it both ways to be sure.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 19-01-2008, 00:01
At least 30 psi is required to operate the solenoid.
Double check that your air input is connected to the correct port (middle one on the side with three ports).
Unread 21-01-2008, 12:32
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
If the spike's LEDs change when you hit the switch, the programming is probably fine.
I would double check the operating psi (it needs to be at least 30 psi), and double check that the tubing is hooked up properly.
When you say it doesn't work, can you feel air coming out one side of the solenoid, and it just doesn't switch sides, or is there no air at all?
Team 2052- KnightKrawler
Mentor and volunteer
Unread 23-01-2008, 22:26
Robert Cawthon's Avatar
Robert Cawthon Robert Cawthon is offline
Robert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to behold
We had the same problem in that we wired it correctly and the programming was correct and the tubing was correct. What we found was that the Fesco solenoid just didn't work. To test this, we pulled one from last year's robot and plugged it in. It worked fine. If you have another one, or a team near you has one, you might try swapping yours out as a test.
Unread 23-01-2008, 23:03
AKA: Bates
FRC #0125 (NUTRONS)
Yeah what happened is they switched it out and went through about 2 more and found one that worked. I still wish I knew what was wrong...
Unread 24-01-2008, 13:10
So do I. We have a Fesco that we can't use. We need to get another one.
Festo Single solenoid JP_1163 Pneumatics 4 24-02-2006 15:07
Single vs double solenoid valve operation Scott358 Pneumatics 0 29-01-2005 11:47
Need instructions for SMC Single/Double solenoid WHou Pneumatics 5 29-01-2005 08:17
using single solenoid like a double SteveO Programming 14 02-02-2004 22:51
Single Solenoid Valve SMC Chubtoad Technical Discussion 3 20-01-2002 15:16
