Go to Post Look around. What else could cause folks to go sleepless for six straight weeks? That's life-changing, isn't it? :D - Billfred [more]
Unread 23-01-2008, 15:56
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Re: This years wheels
Originally Posted by psyco_klown View Post
i dont like the andymark wheels this year that came in the kit. they were all hard compared to last year which were soft and they actually sink in the middle like a u shape. we would have to put them on a lathe to fix them. anyone else have those problems.
I believe last year we were supplied with Andy Mark wheels as well, its been two years since we had Skyway wheels now. The AM wheels with the mounting holes for sprockets are a big improvement over the skyway wheels from the past.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 23-01-2008, 16:35
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: This years wheels
Yes you can modify them. Use them as is if you want, but I would recommend getting them with the precision bearings to match your axle diameter. The stamped bearings will fail. Prices are very reasonable. You will need to make adapters to drive them and space chain if you use chain. I believe Innovation First made hub adapters that still might be available that make it an easier mount if you use chain and sprockets. They were in the KOP when Skyway wheels were offerred.
PS -- AndyMark still has stock (last time I looked) of last year's wheels available, which ae softer. Hoevr some of them faled at he bearing and/or spoke areas, and were beefed up for this year's version. We modified them by filling in the hub space with epoxy/fiberglass to take the hard side hits that caused the bearing to break out of the hub rim.
Unread 23-01-2008, 16:53
elvin23's Avatar
elvin23 elvin23 is offline
not cool
FRC #0354 (354)
elvin23 can only hope to improve
Send a message via AIM to elvin23
i been posting for a lil while and i got a bad rep from the post i edited
I never was a cool guy but i would like to be like the guy in the pic he's cool
Unread 23-01-2008, 20:36
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
IFI has high traction wheels that you can get in 8"
http://www.ifirobotics.com/robot-traction-wheels.shtml
getting four of these runs pretty costly at $335.36 for a set of four wheels, bearings, 22 tooth sprockets and tread.
these are expensive but are very, very nice and work well
Unread 23-01-2008, 22:22
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
Does anyone know where I can purchase the skyway wheels? I took a look at the skyway site and it doesn't seem that they have the 8" with precision bearings.
Please correct me if Im wrong. Thanks!
Unread 23-01-2008, 23:16
Gdeaver Gdeaver is offline
FRC #1640
Contact Skyway and tell them you are a First Team looking for 8" wheel chair wheels they supplied to first. They should be able to help you from there. If you are using the KOP frame then 3/8" grade 8 bolts work good for axles. Tell skyway you want bearing for the axle diameter you are going to use. They sell good bearing with the wheels for a reasonable price. IFI doesn't have the wheel sprocket adapters listed any more. They were expensive. Last year we got a piece of 3/4" LDPE from Mcmaster. Used a 3" hole saw and I believe a 1" to make the donuts. Put them on the wheel hub and mark the spokes in the six points. Use a thick saw blade to make the slots. Get aluminum sprockets from IFI or AndyMark. Center them on the donuts and drill the mounting holes. Use 10-24 socket head bolts with NYlock nuts. Thats what we did last year.
pic: Team 241: This Years Bot Lifting Last Years Bot Dantvman27 Robot Showcase 3 21-02-2007 07:04
Last years versus this years trans. ratios de_ Motors 4 12-01-2006 13:56
Opinion on This Years Game xxerin General Forum 25 09-01-2005 21:45
This Years Window Motors tysonwormus Motors 1 12-01-2003 13:08
This Years GAme EIROBOTICS86 General Forum 47 06-01-2003 12:09
