Go to Post Even better than any [book] is simply becoming an active member of the Chief Delphi forums. Where do you think I got everything I know? - sanddrag [more]
Unread 23-01-2008, 23:33
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Exclamation Code not changing robots function!
Hello,
I was writing some simple code to control the robot feedback LED's on the O/I and whenever i change the code then compile it and program it in, it never changes what the O/I does... So i programed in some drive functions to the robot (other than the default) and they didn't work either...
however if i go to a different computer and open it from the network and compile it then upload it it works!? But if it is compiled on the computer that it is saved on.... It will not work!!
IM SO CONFUSED!
Any sugestions?
Encoders not changing... paulcd2000 Programming 28 18-02-2007 08:34
Changing Code Formatting in MPLAB!!! Yeah!!! Astronouth7303 Programming 1 09-03-2004 18:07
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
Square Root Function not working bludstayne Programming 7 15-02-2004 12:09
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
