Go to Post This is one case where I really wish Andymark didn't listen to their customers so well. - ASD20 [more]
Unread 23-01-2008, 23:49
lemon1324's Avatar
lemon1324 lemon1324 is offline
AKA: Arul S
FRC #2473 (CHS Robotics)
lemon1324 is a glorious beacon of lightlemon1324 is a glorious beacon of lightlemon1324 is a glorious beacon of lightlemon1324 is a glorious beacon of lightlemon1324 is a glorious beacon of light
What is a legal bumper?
Our team has mounted the axles above the kitbot chassis, and the rail is now 2.5" off of the ground. As the bumper zone starts here, we cannot bolt the bumpers directly to the rail. We were thinking of joining the bumpers to each other at each corner to get a rectangular box of joined bumpers. Where exactly is the plywood backing permitted to go in this scenario? (Alternatively, a clarification on the interpretation of "corner" from rule <R08> would help)
Thanks
Unread 23-01-2008, 23:54
Re: What is a legal bumper?
Try this Q&A.
Unread 24-01-2008, 00:35
lemon1324's Avatar
AKA: Arul S
Ah ok--that permits joinery between segments. Our team is more interested in where exactly the join may extend. In short, is it okay for the join to be in "Zone 2" in the attached sketch?
Thanks
Unread 24-01-2008, 00:44
Thanks
That is what is unclear. From the sound of the Q&A answer, yes, if you protect it with a pool noodle.
However, <R08> makes me a liar. See Figure 8-2 and <R08> bullet 11, which reads "Hard bumper parts MUST NOT extend into the corners."
Translation, you may not be in that zone.
Unread 24-01-2008, 01:04
lemon1324's Avatar
AKA: Arul S
Ok thanks
Unread 24-01-2008, 07:46
Arul,
The "corner" in R08 refers to hard edges that can come in contact with other robots. The basis of using the Standard Bumper is so that you and other robots are protected when coming in contact with each other. Contact should only take place in the "bumper zone", bumper to bumper. Use of the kitbot chassis does not prevent you from mounting a standard bumper. The use of aluminum structural angles bolted to the top of the chassis is acceptable. Please remember that the structural material that is used for mounting the Standard bumper, is weighed and sized with the robot, not with the bumpers.
Unread 24-01-2008, 11:05
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Yes, just mount some Aluminum angle to the top of the rail and mount the bumpers to that.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 26-01-2008, 17:12
countryboy_9115's Avatar
countryboy_9115 countryboy_9115 is offline
RoboRev91
AKA: Tyler Bennnett
FRC #1696 (Robo Revolution)
countryboy_9115 is an unknown quantity at this point
Are you sure that we can attatch the bumpers with angle iron? We did not know if you could do that or if you had to attatch the bumpers the way the diagram in the rules shows.
Unread 26-01-2008, 18:19
GaryVoshol's Avatar
Cogito ergo arbitro
The bumper has bolts of some kind going through it. Those parts, and only those, are exempt from the size and weight limits of the robot.
The robot has pieces of angle attached to the frame, with holes for the bumper bolts to be fastened through. Those parts are included in the size and weight limits.
All very legal.
(since 2004)
Unread 26-01-2008, 18:23
Scott Carpman's Avatar
Scott Carpman Scott Carpman is offline
FRC #1155 (SciBorgs)
Scott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud of
When in doubt, pool noodles.
RPI '12
Unread 24-01-2008, 07:39
GaryVoshol's Avatar
Cogito ergo arbitro
Thanks
I concur with Eric. I wondered how the "joinery" referenced in the Q&A would jibe with <R08>.
Note: Joinery is a woodworking term for connecting two pieces of wood to each other, via methods such as dovetails or biscuits. It does not refer to connecting pieces together with brackets, hinges, etc.
Edit: Since bumpers are required this year, I would make sure that any specific designs that might be questioned by an inspector get pre-approved via the Q&A. You can't just take off non-conforming bumpers this year!
(since 2004)
Bumper Qs Woody1458 General Forum 13 29-01-2009 16:41
bumper coolguybigt Technical Discussion 4 27-02-2007 16:40
Bumper Kits FRC1710 Kit & Additional Hardware 1 22-02-2007 20:29
Bumper sensors jbill30 Programming 1 01-05-2006 18:49
Bumper or No? WebWader125 Technical Discussion 19 11-01-2006 01:28
