Go to Post Without fail, judges always come by when the spokespeople are in the bathroom, so others should be able to cover until they're back. - Jacob Bendicksen [more]
Unread 23-01-2008, 21:32
Mikhail_Pham Mikhail_Pham is offline
Mikhail_Pham is an unknown quantity at this point
Hitec H-322HD Servo + 3.6 lbs of metal = success?
We were wondering if a Hitec H22HD servo could swing a 3.6 arm in a circular fashion in a side to side motion with any success. We're kind of at a loss at how to calculate it. The specifications are:
Control System: +Pulse Width Control 1500usec Neutral
Required Pulse: 3-5 Volt Peak to Peak Square Wave
Operating Voltage: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C
Operating Speed (4.8V): 0.19sec/60° at no load
Operating Speed (6.0V): 0.15sec/60° at no load
Stall Torque (4.8V): 42 oz/in (3.0 kg/cm)
Stall Torque (6.0V): 51 oz/in (3.7 kg/cm)
Current Drain (4.8V): 7.4mA/idle and 160mA no load operating
Current Drain (6.0V): 7.7mA/idle and 180mA no load operating
Dead Band Width: 5usec
Operating Angle: 40 Deg. one side pulse traveling 400usec
Direction: Clockwise/Pulse Traveling 1500 to 1900usec
Motor Type: Cored Metal Brush
Potentiometer Drive: 4 Slider/Direct Drive
Bearing Type: Top/Resin Bushing
Gear Type: Heavy Duty Resin
360 Modifiable: Yes
Connector Wire Length: 11.81" (300mm)
Dimensions: 1.57" x 0.79"x 1.44" (40 x 20 x 36.5mm)
Weight: 1.52oz (43g)
Any help as to how we would calculate the feasibility of such an application would be very much welcome.
Thank you in advance.
Unread 23-01-2008, 21:36
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Hitec H-322HD Servo + 3.6 lbs of metal = success?
Torque = Force * Distance. You have a stall torque of 51 oz-in. Assuming that the mass of your arm is uniformly distributed, then the absolute maximum length that your arm could be is 1.77 inches. I'm guessing that that's not going to work for your application.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 23-01-2008, 22:37
dtengineering's Avatar
AKA: Jason Brett
I believe we are also allowed to use VEX continuous rotation motors this year as well, are we not? You could gear a vex motor (essentially a continuous rotation servo) down many, many, times and get a slow movement, perhaps.
If you want a servo style motor hookup take a look at the FP and Banebots motors in the KOP and consider a banebots planetary transmission for them. Plug a variable resistor into the output shaft, so as the shaft moves, the resistor turns. Read the voltage of the resistor with an analog input on the RC and then program the motor to move the resistor to the desired setting.
Or just use lots and lots and lots of the servos... I believe the rule says "unlimited numbers" doesn't it?
Jason
Unread 23-01-2008, 23:49
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
True, but there is a finite number of PWM ports on the Robot Controller, and you can only connect servos to the PWM ports (Rule <R62>), so....
-dave
Unread 24-01-2008, 00:43
Alex698's Avatar
Alex698 Alex698 is offline
Sparky
FRC #2449 (Out of Orbit Robotics)
Alex698 is a jewel in the roughAlex698 is a jewel in the roughAlex698 is a jewel in the rough
Send a message via AIM to Alex698
Originally Posted by dlavery View Post
True, but there is a finite number of PWM ports on the Robot Controller, so....
-dave
make use servo PWM Y-Cables!
All we need now is a Servo-driven shifting gearbox.
Eat, Sleep, Build Robots
Unread 24-01-2008, 02:11
dlavery's Avatar
Curmudgeon
And given that the total combined current supplied from all 16 Analog and 18 Digital +5V Power header pins on the Robot Controller is 1 Amp, and each VEX servo can pull up to 1.5 amps, how many times can you get away with that?
Using multiple VEX servos and VEX motors is certainly within the rules. But the capabilities of the system hardware makes the number of possible configurations somewhat self-constraining.
-dave
Unread 24-01-2008, 16:57
mneary mneary is offline
FRC #1759
mneary is an unknown quantity at this point
Send a message via AIM to mneary
In the ifirobotics FAQ (December 2004), they state that "The total combined current that can be supplied from all 16 PWM Output +7.2V header pins is 4 Amp. This current is supplied from the Backup Battery."
Earlier the stall torque was used to calculate the force you can use... operating a motor in stall for more than a second or so will often let the magic smoke out.
Unread 24-01-2008, 17:26
AdamHeard's Avatar
Lead Mentor
What do you need this motion for? There is probably a better way to actuate it.
Can we use Servo Hitec#HSR-5995TG ks_mumupsi Motors 2 12-01-2008 12:32
HITEC Servos MarkW Motors 2 05-02-2007 11:01
HiTec Robonova jparkteach Math and Science 12 14-04-2006 04:07
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
2002 Kit Hitec Servo Part Number kmcclary Motors 6 03-12-2002 11:49
