Go to Post Whether we realize it or not, we've all been touched by the works of Dr. Kamen - through his TED talks, through his research and scores of publications in pediatric oncology, or perhaps more directly through his daughter. What an incredible life, what an incredible legacy. - Taylor [more]
Unread 24-01-2008, 00:28
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Shaft encoder in KOP transmission?
We took the second stage out of the KOP transmissions, and have the bad GTS issue to deal with, and I found this sensor at digikey
http://rocky.digikey.com/scripts/Pro...102&M=AMT102-V
looks like it might fit right inside the transmission where the other gears used to be, and slip over the 8mm (5/16") shaft of the motor, and maybe even work, and for only $30 per side.
what do you think?
Quadrature shaft encoder source billbo911 Kit & Additional Hardware 7 06-01-2008 19:52
Problem using VEX shaft encoder jskene Programming 15 28-10-2007 22:33
VEX Shaft Encoder Kit jeffmorris FIRST Tech Challenge 1 19-05-2006 12:23
Which shaft encoder to use? Jeff Waegelin Electrical 22 18-06-2005 03:57
shaft encoder help stephenthe1 Programming 2 03-12-2004 16:09
