Go to Post Unfortunately, there's no special type of transmission that will magically get you past defense. The best way to deal with defense is to practice, regardless of gearing. - connor.worley [more]
Unread 24-01-2008, 04:49
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: Camera Works Well with the Balls!
Originally Posted by JHale View Post
The main difference is turning over servo control to the camera, instead of the controller.
As has been stated previously, you can't have the camera control servos, unfortunately.
In collecting output, I had noticed that the camera would tell the controller that it had sufficient confidence to start tracking, however, if the next packet denies this (perhaps the ball has moved and the confidence is slightly decreased) the code restarts.
If you're willing to give Kevin's code another, slightly different, go, try the drop-in replacement for tracking.c here. It's a modification I did last year that deals with just the problem you stated by not dropping the camera lock unless it loses the target for several consecutive frames. Success rate was over 80% (I don't have specific numbers at the moment) tracking last year's lighted targets with no recalibration ever needed, even between venues, so give it a try if you want.
--Ryan
Camera did not work for well at the regionals, but worked great at home. Alan Ing Programming 12 17-04-2006 17:43
1281's camera isnt working too well ThomasH Regional Competitions 1 31-03-2006 00:27
Blocking balls with balls allowed? MrBamboo Rules/Strategy 16 27-01-2006 19:59
Help with the balls! tchescow Kit & Additional Hardware 11 20-01-2004 10:52
Will ANYONE mess with the black balls? archiver 2001 0 23-06-2002 22:35
