Go to Post FIRST has a 365 day season (366 on leap years)... - Adam Richards [more]
Unread 23-01-2008, 16:57
Philz20 Philz20 is offline
MGSH Coder
FRC #2526 (Team 2526)
Philz20 is an unknown quantity at this point
Joystick sensitivity
Hey guys, I'm having trouble with the sensitivity of my joystick. We are running a 4-motor setup and the joystick causes the robot to speed up and turn too quick with the slightest movement of the joystick. Turning the robot causes a quick jerk which is giving us control issues. Are there any block functions in easyC to adjust the sensitivity? This is my team's first year in FIRST and the first time I'm doing C programming, so my understanding of the code is basic at best. Any help will be much appreciated.
Philip Kirshbaum
Maple Grove Senior High
Head of Programming and Control Systems, Team 2526
Unread 23-01-2008, 17:29
angelc24's Avatar
angelc24 angelc24 is offline
A Pirate's Life For Me...
AKA: Christina
FRC #0467 (Duct Tape Bandits)
angelc24 has a spectacular aura aboutangelc24 has a spectacular aura aboutangelc24 has a spectacular aura about
Send a message via AIM to angelc24
Re: Joystick sensitivity
This is what we have used for the past few years as ramping code :
long ramping (unsigned char ramp)
    long answer = 0;
    answer =  ((long)ramp - 127);
    answer = ((answer) * (answer) * (answer));
    answer = ((answer) / (128 * 128));
    answer = (answer) + (127);
    return answer;
We've never used EasyC, so I don't know if there's anything there to help you...
"You need people of intelligence on this sort of mission....quest.....thing."
"Where did all the food go?"
"Ask the programmers."
"Whether a bot is made of new parts, old parts or spare parts, you can shine no matter what you're made of"
2005 Delphi Driving Tomorrow's Technology Award
2006 Xerox Creativity Award
2006 Delphi Driving Tomorrow's Technology Award
2007 Johnson and Johnson Sportsmanship Award
2008 Judges' Award
Unread 23-01-2008, 17:36
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
Hi, I really like the idea of your ramping function. I was wondering if you could provide some reasoning behind your calculations. I would like to know the thought procedure behind the steps.
Unread 23-01-2008, 17:38
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
That code above should produce a curve that reduces the motor outputs when the joystick is at a low level, but still maintain a max speed. (See attachment.) Of course, you could just multiply by some fraction, but that decreases your top speed. Or maybe reduce speed when motors are turning in opposite directions, (turning?)
The reason it's cubed is to get that sort of curve for the entire function. The random huge number in there is 128, (the maximum value) squared. It's basically to center the cubic equation on 128,128. (I believe I came up with it with experimentation on a graphing calculator, I really forget why it works)
Unread 23-01-2008, 17:40
Let us not forget that the speed controllers have a calibrate function. If you do not provide for one in your code then follow the calibrate procedure in the 884 manual available on the IFI website. This insures that the controller learns the full travel of your joystick, the end points of travel and the center rest position.
Unread 23-01-2008, 18:27
MiniNerd24's Avatar
MiniNerd24 MiniNerd24 is offline
Are you going to eat that?
FRC #2039 (Rockford Robotics)
MiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the rough
If you're using ROBOTC after the [p1_y] statement in " motor[port1] = frcRF[p1_y] just add the division sign ( / ) and put a number down (we're using 5)
This is what it should look like.
motor[port1] = frcRF[p1_y/5];
and that's all.
hope this helps.
The system is down.
Rockford Robotics 2039: Think outside the bots.
Unread 23-01-2008, 18:32
AKA: A. King
Only problem with actual division is the reduction of max speed. You can only go up to one fifth of your mechanical maximum with that code. Another thing we did last year was have a 'precision button,' that divided the value only when you pressed a certain button. That way you can limit responsiveness but not speed using true division.
Unread 23-01-2008, 18:36
MiniNerd24's Avatar
You sure? We got max speed even when we divided directly but, hey, I'll take your word for it.
The system is down.
Unread 23-01-2008, 20:08
AKA: A. King
I'm fairly sure. Unless... What is your frcRF function? If that's a ramping function, I wouldn't think that's direct division. (I've never used RobotC anyway.)
If it's not, you might not be getting the max speed, as the maximum value you're getting from the joystick (256) divided by 5 is 51. That's less than your max of 127, (or 256 if that's how you're using the values.) Whatever works for you. (Though I'd check just in case you don't really know your max speed.) Good luck.
Unread 23-01-2008, 21:30
MiniNerd24's Avatar
Thanks, looks like you're the one helping me instead.
(But just for a teaser, our robot moves (at max speed of course) at 10 ft.ps)
I don't know where the site is but it is in a thread called FREE ROBOTC FOR FIRST MEMBERS
The system is down.
Unread 24-01-2008, 08:34
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Here on Team 612 we've used the cube function for several years. It gives the drivers much better control at low speeds.
We also include an acceleration limiter, which eliminates any chance of tripping the circuit breakers. We do this by allowing the PWM signal sent to the drive motors to increase by only a certain amount on each pass through the user routine.
This reduces the maximum current sent to the motors. It also minimizes strain on the drive system (chains, belts, tread wear, etc.). The effect on the robot's performance on the field is barley noticeable.
This year, however, we are doing something completely different....
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
joystick sensitivity hanan Control System 4 19-01-2007 05:36
Accelerometer Sensitivity zachriggle Programming 0 27-01-2006 23:16
White Paper Discuss: Joystick Sensitivity Demystified - Version 2 marccenter Extra Discussion 0 28-02-2005 16:54
joystick sensitivity Team 668 Programming 11 16-02-2005 18:45
Help with Joystick Axes and Sensitivity bglass Programming 6 06-02-2005 14:01
