Go to Post Weight down low is a good thing. Weight up high is not. - s_forbes [more]
Unread 24-01-2008, 09:20
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Question about the Pressure Switch
hey,
Our Pressure switch stops at 110psi.
Any idea why?
Thanks,
TEAM 2230 ZECHARIA'S ANGELS
2009 Microsoft Israel FRC Regional Winners!
2009 Microsoft Israel FRC Regional Chairman's Award Winners!!!
2008 Microsoft Israel FRC Regional semi-finalist.
2008 Microsoft Israel FRC Regional Delphi's "Driving Tommorow's Technology" Award winner.
2008 Robot Driver
2007 GM/Technion Israel FRC Regional semi-Finalist.
2007 GM/Technion Israel FRC Regional Xerox Creativity Award winner.
2007 Robot Driver.
Last edited by Bomberofdoom : 24-01-2008 at 15:11. Reason: was not me who mispelled at first post
Unread 24-01-2008, 09:23
Re: Question about the Pressure Switch
The pressure switch is not terribly accurate. That being said, it should allow your system to reach in the 120-130 PSI range. It might be defective and would then need to be replaced.
Unread 24-01-2008, 09:28
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The pneumatics manual says it is supposed to trip at 115 psi.....
Unread 24-01-2008, 11:00
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
ours has always tripped at 110 - 115 psi indicated pressure. We run the compressor 5-7 seconds longer to reach 120 (programming).
pressure switch wiring question... Transformers Pneumatics 11 16-02-2008 12:55
what is the pressure switch? Reaper40 Pneumatics 2 25-01-2007 18:52
Pressure Switch Wiring Question Matthew_H Electrical 4 16-02-2004 01:25
Pressure Switch Wiring Question Matthew_H Control System 1 08-02-2004 15:28
Question about Pressure Switch Randy_Ai Technical Discussion 1 30-01-2002 18:29
