Go to Post It is probable that you will find mroe than a few spotlight worthy phrases or sentences in the following. ;) - sanddrag [more]
Unread 24-01-2008, 09:28
Re: WPILIB: WriteSerialPortOne(unsigned char) Warning on Compile
Double quotes denote a string, which is a pointer in C. For a character, use single quotes.
Unread 24-01-2008, 09:44
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Gotcha!
WriteSerialPortOne('J');
Works like a champ. I got PLC code on the brain this morning...not C code...need more coffee....
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Signed and unsigned variables dmlawrence Programming 4 05-01-2008 23:03
Code Won't Compile in MPLab with WPILib Inverted Programming 1 20-02-2007 22:12
Printf warning during compile? actorindp Programming 4 20-02-2004 17:02
problems assigning unsigned chars in FRC Code LoyolaCubs Programming 6 26-01-2004 23:21
Dashboard programs and the char variable Ian W. Programming 13 26-06-2002 02:07
