Go to Post I'd rather have a bot in front of me than a frontal lobotomy. - Neal Probert [more]
Unread 24-01-2008, 09:09
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
WPILIB: WriteSerialPortOne(unsigned char) Warning on Compile
We are trying to write a new ASCII driver function within EasyC Pro.
I see that WPILIB supports WriteSerialPortOne(unsigned char).
If we add this as a C Code block and call the serial port write function, the code complies but we get a WARNING.
Is this a normal warning to see?
"suspicious pointer conversion"
The supported WPILIB serial functions we are aware of.
unsigned char ReadSerialPortOne(void);
void WriteSerialPortOne(unsigned char);
unsigned char ReadSerialPortTwo(void);
void WriteSerialPortTwo(unsigned char);
unsigned char GetSerialPort2ByteCount(void);
unsigned char GetSerialPort1ByteCount(void);
void OpenSerialPortOne(unsigned baudRate);
void OpenSerialPortTwo(unsigned baudRate);
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 24-01-2008, 09:28
Re: WPILIB: WriteSerialPortOne(unsigned char) Warning on Compile
Double quotes denote a string, which is a pointer in C. For a character, use single quotes.
Unread 24-01-2008, 09:44
Controls Engineer
AKA: chakorules
Gotcha!
WriteSerialPortOne('J');
Works like a champ. I got PLC code on the brain this morning...not C code...need more coffee....
Favorite CD quote:
Signed and unsigned variables dmlawrence Programming 4 05-01-2008 23:03
Code Won't Compile in MPLab with WPILib Inverted Programming 1 20-02-2007 22:12
Printf warning during compile? actorindp Programming 4 20-02-2004 17:02
problems assigning unsigned chars in FRC Code LoyolaCubs Programming 6 26-01-2004 23:21
Dashboard programs and the char variable Ian W. Programming 13 26-06-2002 02:07
