Go to Post It's a skid-steer vehicle, so it depends on the phase of the moon and yesterday's lottery numbers. - Ether [more]
Unread 24-01-2008, 12:14
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Volume Accumulators
NEED TO KNOW ASAP:
Can we use a comperable volume accumulator to the ones provided or are we required to purchase extra ones from Clippard?
Thanks
Unread 24-01-2008, 12:35
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Volume Accumulators
You must use ones identical to the ones in the kit and are limited to 4 of them. Identical means same manufacturer and part number.
Unread 24-01-2008, 12:45
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
No. That would be a violation of Rule <R01> and Rule <R86>.
The answer is from the GDC Q & A
Unread 24-01-2008, 13:56
The applicable rule in part from Section 08, REV D is...
<R87> Additional pneumatic system items specifically permitted on 2008 FRC ROBOTS include:
 One or two additional Clippard air storage tanks (Clippard Part Number AVT-32-16),
equivalent to those provided in the kit. This means that up to four, and no more, Clippard air
storage tanks can be used on the ROBOT.
Use the order form that came in your KOP for additional Clippard parts.
Unread 24-01-2008, 14:49
rsegrest's Avatar
Thanks for the clarification. Between R89 and R90 I wasn't sure and just wanted to get it straight before we orderd the wrong thing.
Clippard Accumulators Gherkinman Inventor 3 09-02-2007 20:33
Compressors vs. Accumulators Pavan Dave Pneumatics 6 31-01-2007 09:46
Using pre-charged accumulators Peter Matteson Pneumatics 8 14-02-2006 10:42
Music Volume at the Competitions Alex Golec Regional Competitions 27 02-02-2005 16:19
Volume of tank + tube blindguyinanorg Pneumatics 8 18-02-2004 00:32
