Go to Post "If everything is possible, there is the possibility that something is impossible..." ::sigh:: :) - Kims Robot [more]
Unread 24-01-2008, 12:54
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Banebots 1/2" shaft encoder for Toughbox?
It was actually made to fit last year's Banebots KoP transmission (which had mounting holes for it).
Word of warning though. Unless you pre-plan the mount strategy and carefully machine your mounting surface to have the mounting holes EXACTLY where they need to be, you will encounter problems. 116 attempted to use these on our 1/2" drive axles last year, and encountered a number of problems with mounting them. I'd highly suggest carefully machining your mounting plate, if not CNCing it.
I have not heard any complaints about these when used with the Banebots transmissions they were intended for though.
2008 Toughbox vs. Banebots vs. 2006 Gearbox team 2191 Technical Discussion 5 20-01-2008 15:20
BaneBots Encoder Chip # whytheheckme Electrical 1 18-02-2007 16:36
shaft encoder help stephenthe1 Programming 2 03-12-2004 16:09
Wiring "3-pin" Shaft Encoder. Joel J Programming 7 27-02-2004 17:21
supplier for 5/8" shaft david.clark Kit & Additional Hardware 2 17-01-2004 18:13
