Go to Post I think AndyMark just sold out of rabbits feet. - BRAVESaj25bd8 [more]
Unread 24-01-2008, 12:49
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Banebots 1/2" shaft encoder for Toughbox?
I was looking at the banebots web page, and found this
http://banebots.com/pc/ELECTRONICS/EN-G0561-KT
it's a quadrature shaft encoder with 128 resolution that mounts on a flat surface and works with a 1/2" shaft.
Like it was made to put on a KOP transmission....
Unread 24-01-2008, 12:54
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Banebots 1/2" shaft encoder for Toughbox?
It was actually made to fit last year's Banebots KoP transmission (which had mounting holes for it).
Word of warning though. Unless you pre-plan the mount strategy and carefully machine your mounting surface to have the mounting holes EXACTLY where they need to be, you will encounter problems. 116 attempted to use these on our 1/2" drive axles last year, and encountered a number of problems with mounting them. I'd highly suggest carefully machining your mounting plate, if not CNCing it.
I have not heard any complaints about these when used with the Banebots transmissions they were intended for though.
Unread 24-01-2008, 13:00
MrForbes's Avatar
AKA: Jim
perhaps we could make an adjustable mounting plate...the encoder screws into the plate, the plate is larger and has "loose" mounting holes to allow precise positioning.
I wonder how much radial shaft runout is allowed? looks like it could probably tolerate a little bit.
Thanks for the info!
Unread 24-01-2008, 13:17
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
We used them last year with the Banebots. I can not remember off hand how we mounted them. Which probably means it was fairly easy. The only downfall that I remember was that the encoded ring gets glued to the shaft. Luckily with our self made double d plates we did not have to replace the Banebots. We were concerned that removing it from the shaft would damage it if we needed to replace the Banbots.
Unread 24-01-2008, 13:26
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Yes they work well when mounted properly. Our team, however, machines to a precision of .25 inches which isn't good enough for these. Last year the Banebot transmissions had the mounting holes for these encoders, but the output shaft axial play was greater than the gap for the encoder wheel. We killed a few encoders. But if you can get them mounted and positioned correctly on this year's transmission, they will work well. Try to avoid using an adjustable mount strategy unless you can be sure it won't move once you get it straight. The only thing worse than having no encoders is having unreliable encoders.
Unread 24-01-2008, 13:29
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
I would not recommend the BaneBots encoders at all. We used them with the BaneBots transmissions as intended, and encountered many problems.
An excerpt taken from a previous post I made:
Originally Posted by whytheheckme View Post
...... but the BaneBots encoders are constructed poorly, and after a few matches, the superglue (Yes, Superglue) thats holding the encoder wheel to the shaft starts to heat, and allows the wheel to move around, and eventually grind up against the encoder, rendering them useless. I would not recommend the BaneBots encoders.
In short, if everything isn't perfect, these will break in a flash.
Jacob
Unread 24-01-2008, 13:32
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
This bears repeating. We had a lot of trouble getting the encoder wheel to actually stay fixed to the shaft last year. Not recommended.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 24-01-2008, 13:41
MrForbes's Avatar
AKA: Jim
how about a spacer, broach a keyway and use a lock collar to hold it on?
It starts to look like work, though.
Did anyone use their divider circuit?
Unread 24-01-2008, 13:49
AKA: Dan
Axial distance isn't such a concern, because you mount the encoder wheel according to where the sensor is located. It slides on the axel and gets super glued in place. The trick is to get the radial distance just right, then mount to the transmission via stand offs. You guys might be able to get it right. Maybe use a template with a temporary bearing/shaft in it to get the mounting holes just right, then transfer the holes to the real transmission. Also note that on the other side of the transmission plate is the output gear, so there's not much clearance for mounting hardware.
We never made the divider cards. You would think with all the EE students on our team someone would know how to solder!
Unread 24-01-2008, 15:01
dtengineering's Avatar
AKA: Jason Brett
We used the BB encoders and divider cards without problems... well, at least without problems we couldn't fix... last year.
There is a little allowance for shaft runout... last year with the BB trannies we had some runout issues, and the metal encoder disc ended up grinding down the sensors on one encoder. It had to be replaced. The blame for that lies more with the tranny and us than it does with the encoder.
We did not have any problems super-gluing the encoders to the shafts... just make sure they are on square, or the room you have to deal with run out gets eaten up quickly.
The divider cards worked great and really took a load off the programmers and processor.
That said, we're using gear tooth sensors this year. Or at least we're planning on it... that part of the code isn't implemented yet.
Jason
Unread 24-01-2008, 15:04
MrForbes's Avatar
AKA: Jim
Thanks for all the comments about your experiences with the BB encoders, it's a big help!
Unread 24-01-2008, 21:40
DonRotolo's Avatar
Back to humble
FRC #0832
Yes, we used the divider circuit, our programming team found them a lot easier to program against, and we didn't experience any problems.
2008 Toughbox vs. Banebots vs. 2006 Gearbox team 2191 Technical Discussion 5 20-01-2008 15:20
BaneBots Encoder Chip # whytheheckme Electrical 1 18-02-2007 16:36
shaft encoder help stephenthe1 Programming 2 03-12-2004 16:09
Wiring "3-pin" Shaft Encoder. Joel J Programming 7 27-02-2004 17:21
supplier for 5/8" shaft david.clark Kit & Additional Hardware 2 17-01-2004 18:13
