Go to Post its like the championship being ice cream, its pretty awesome IRI is like adding toppings, making it even more awesome - Aren_Hill [more]
Unread 24-01-2008, 13:17
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
Re: Banebots 1/2" shaft encoder for Toughbox?
We used them last year with the Banebots. I can not remember off hand how we mounted them. Which probably means it was fairly easy. The only downfall that I remember was that the encoded ring gets glued to the shaft. Luckily with our self made double d plates we did not have to replace the Banebots. We were concerned that removing it from the shaft would damage it if we needed to replace the Banbots.
2008 Toughbox vs. Banebots vs. 2006 Gearbox team 2191 Technical Discussion 5 20-01-2008 15:20
BaneBots Encoder Chip # whytheheckme Electrical 1 18-02-2007 16:36
shaft encoder help stephenthe1 Programming 2 03-12-2004 16:09
Wiring "3-pin" Shaft Encoder. Joel J Programming 7 27-02-2004 17:21
supplier for 5/8" shaft david.clark Kit & Additional Hardware 2 17-01-2004 18:13
