Go to Post I have never before seen the words "smaller" and "Saturn V" used in the same sentence. Wow. :yikes: - DonRotolo [more]
Unread 23-01-2008, 16:43
RoarRoar RoarRoar is offline
RoarRoar is an unknown quantity at this point
Motor Controller
Hello
This HB-25 Motor Controller from http://parallax.com will work on FRC Robot Controller. but I wonder do I need to write code? or how do this work on FRC Robot Controller?
I need only a small Motor Controller max 5A. I will control 4 electric motor.sow I need 4 HB-25 Motor Controller. The HB-25 Motor Controller is inexpensive.if I buy 4 Victor 884 Speed Controller will this cost me 560 dollar. the 4 HB-25 Motor Controller cost only 50 Dollar for one (200 dollar)
I need only a Motor Controller that work on a FRC Robot Controller,not a Victor 884 or 883 Speed Controller it is expensive for me, and i dont need sow many A
this project is not to a robot,but to a submarine (rov)
Unread 23-01-2008, 17:03
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
Re: Motor Controller
It should work on the FRC controller the same as a Victor 884. You should be able to use any of the same code that would work with the Victor. For a ROV, you are going to have to write code, the default code from IFI for a robot is probably not going to do what you want.
It looks like a nice motor controller, I may have to invest in a couple to play with.
Good Luck.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 24-01-2008, 15:05
ok thanks!
Then I will order 4 HB-25 Motor Controller from http://parallax.com. and see how this will work.
But about joystick wher can I buy that with standard Analog 15pin??
I have search on Internet, but I can find anything, only with USB?
(I need 2 standard Analog joystick)
Unread 24-01-2008, 16:01
Here, try this site. They supply the joysticks that the FIRST Robotics teams get in their kit of parts. Go straight to the bottom of the page; it's the one labeled "Analog".
Teams often modify them to suit their needs.
Unread 24-01-2008, 21:32
DonRotolo's Avatar
Back to humble
FRC #0832
For joysticks, also it is possible to use a "USB Chicklet" to make a USB joystick work OK. Search this forum for more information. IFI sells them.
Don
Serial PWM motor controller smartkid Technical Discussion 18 30-12-2007 12:35
Hooking up a motor to Vex controller Jeremiah Johnson VEX 2 15-08-2006 19:36
Globe motor to spike controller stephenthe1 Motors 25 19-02-2006 23:03
purchase motor controller wkethman Electrical 7 09-01-2006 09:16
Help - Gear Motor Controller dteshome Motors 17 13-05-2003 15:13
