Go to Post The game is going to be exciting. I want a front row seat and a big box of buttered popcorn. - JaneYoung [more]
Unread 24-01-2008, 13:19
jonboy jonboy is offline
Engineer/Mentor
FRC #0885 (The Green Team)
jonboy is an unknown quantity at this point
EasyC Assignment rules
Question is where can I get the assignment rules when using mixed types in an assignment expression. Does ANSI C apply? TNX
... jon
Unread 24-01-2008, 13:22
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: EasyC Assignment rules
Can you please explain a little bit further as to what you are referencing, and perhaps what you are trying to do?
We'd love to help! Just need more info.
Jacob
Unread 24-01-2008, 16:45
The place where Microchip C diverges significantly from ANSI C is exactly what jonboy was asking about.
What you need to know is this: the compiler looks at the size of the operands when choosing the precision of the operator, and picks the smallest number of bits that will fit both operands. It doesn't care about the size of what you're storing the result in. If you're adding or multiplying two chars, the answer will be a char and overflow will be an issue. The typical workaround is to cast one of the operands as (int) in order to force the compiler to do 16-bit arithmetic instead of just 8.
Unread 27-01-2008, 11:07
Engineer/Mentor
Alan:
TNX for the reply. You hit the nail on the head. I was hoping the EasyC expert on the board would have the definitive answer. Not a big deal, but it would remove some of the mystery sooner and with greater ease.
TNX agn
... jon
Unread 28-01-2008, 16:36
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
If you are looking for the sizes open the help file click on "Index" and type/paste
"Variable definitions table"
MS Vista/EasyC & EasyC Pro rswsmay Programming 1 25-04-2007 10:47
Help on a Homework Assignment. Pavan Dave General Forum 1 13-09-2006 14:20
Kickoff easyC workshop integrated into EasyC help file Dan Larochelle Programming 0 11-01-2006 06:12
Student assignment at Championship Andrew Schuetze Team Organization 7 07-04-2005 23:24
