Go to Post What's the reason for having a rule if it's not enforced? - jpsaul7usa [more]
Unread 22-01-2008, 21:02
wildabyss wildabyss is offline
wildabyss is an unknown quantity at this point
taigene motor shaft
Taigene motor has a rectangular end on its shaft. What coupler should I use to, for example, connect it to a 1/2'' shaft?
Unread 22-01-2008, 21:59
Jaybee1405
Posts: n/a
Re: taigene motor shaft
possibly mount a gear on the output shaft of the Taigene and on the 1/2 inch shaft and mesh the gears together
that way you'll also be able to control the reduction
Unread 23-01-2008, 11:56
LH Machinist LH Machinist is offline
LH Machinist has a spectacular aura aboutLH Machinist has a spectacular aura aboutLH Machinist has a spectacular aura about
The main shaft is 11mm round and the easist method of attachment is; drill your pulley to 11mm (slightly smaller than 7/16) and then use a 3/32 roll pin to secure it to the motor shaft.
Unread 24-01-2008, 17:11
A large portion of the shaft has a rounded rectangular shape. Is there any easy way to use that?
Taigene Window Motor Information CoupeSprinter Motors 4 29-01-2008 20:27
Taigene Window Motor Specs master_nickz General Forum 0 22-01-2008 15:53
Taigene Motor Specs Guy_E Motors 7 21-01-2008 03:25
White Paper Discuss: Approx. Motor Spec for Taigene Motor Joe Johnson Motors 2 22-01-2005 16:36
Drill Motor and FP Motor Shaft Diameters Andy Baker Motors 4 11-06-2001 20:12
