Go to Post "Well-resourced" teams with "deep pockets" don't just spring up, they are usually the result of a lot of hard work. - artdutra04 [more]
  #61   Spotlight this post!
Unread 24-01-2008, 18:21
Re: Trackballs
Originally Posted by chinckley View Post
I do not understand this from Q&A...
Touching the rack while hurtling
Are there any limitations on touching or hitting the rack while hurtling?
Re: Touching the rack while hurtling
Restrictions on contact between the Robot and the Overpass are defined in Rule <G34>.
Restrictions on contact between the Robot and The Rack are much more severe, as they would have to involve reverse time travel.
What does this mean?
You are looking at a reference to the 2007 game's central scoring structure, the Rack (from Rack and Roll). Hence the reverse time travel. The Overpass has been called the rack by mistake.
  #62   Spotlight this post!
Unread 24-01-2008, 18:50
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Trackballs
Do you know what they are using to tell the size?
How do we know when it is inflated correctly?
Take a look at page 11 of section 10 of the manual... not perfect by any means, but a pretty decent guide.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
  #63   Spotlight this post!
Unread 24-01-2008, 19:42
chinckley chinckley is offline
Winner 2009 West Michigan District
FRC #1254 (Entropy)
chinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to all
Re: Trackballs
This actually came from the 2008 Q&A system.
It was the question and answer.
It was posted on 1-15-08 by team 1350.
2009 West Michigan District Winner
Thanks to Team 216 and Team 1918
2009 Traverse City Semifinalist
Thanks to Team 1596 and Team 47
2009 Traverse City UL Safety Award Winners
Attending 2009: West Michigan, Traverse City, & State
  #64   Spotlight this post!
Unread 24-01-2008, 19:43
mastercadman's Avatar
mastercadman mastercadman is offline
None #1764
mastercadman is an unknown quantity at this point
Re: Trackballs
if you check the manual under 6.3 it says that the trackball is 40" diameter and approximately 10 lbs. but update 4 its states that the trackball actually 7.3 lbs. To inflate the ball check the manual because it has an entire section on inflating the trackball to the right spot.
  #65   Spotlight this post!
Unread 24-01-2008, 19:45
Re: Trackballs
I know. Hence the reverse time travel.
Allow me to explain: in 2007, the scoring structure was known as the "Rack". The 2008 scoring structure is the "Overpass". So, when someone asked about scoring on the rack (thinking of the overpass), the GDC responded that the rules for contacting the Overpass could be found in <G34>. But the rules on contacting the Rack (last year) involve reverse time travel (i.e. traveling back in time and contacting the Rack).
  #66   Spotlight this post!
Unread 24-01-2008, 19:56
FRC #1254 (Entropy)
Re: Trackballs
That would explain why I did not understand what they meant at all.
Thanks.
  #67   Spotlight this post!
Unread 25-01-2008, 10:38
MedievalWarrior MedievalWarrior is offline
FRC #1254 (Entropy)
MedievalWarrior is an unknown quantity at this point
Re: Trackballs
How do we prevent the balls from popping during the actual competition?
  #68   Spotlight this post!
Unread 25-01-2008, 11:10
Re: Trackballs
You design your robot to not endanger them. Among other things, see rule <R05> regarding sharp corners and edges.
