Go to Post If your prototype works perfectly, you've been working on it too long. - Blair Frank [more]
  #286   Spotlight this post!
Unread 24-01-2008, 13:42
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Re: New C18 3.0+ Compatible FRC Code
I just discovered something else interesting about the gyro code... specifically the way the angle resolution relates to the analog input scaling.
I detected this as I was logging heading data as I was driving around and around our track.
On my system I have 4 Analog inputs, that I'm running 4 amples per update at 1600 Hz... This give me a Gyro update rate of 100 updates per second, and an ADC Range of 2048 and
In the Gyro code... for an ADXRS150 I have
#define GYRO_SENSITIVITY_RAD 1396L // in units of milliradians/sec/volt
And finally I have
long Get_Gyro_Angle(void)
// Return the calculated gyro angle to the caller.
return(((gyro_angle * GYRO_SENSITIVITY * 5L) / (ADC_RANGE * ADC_UPDATE_RATE)) * GYRO_CAL_FACTOR);
So, since I've been caught before on this one.. I calculated the value of the divisor of this expression. ADC_RANGE * ADC_UPDATE_RATE = 2048 * 100 = 204800. So I'm dividing a "Long" by this number.... I should be able to calculate the maximum result I can get...
Max Long is 2147483648 so if I divide this by 204800 I get 10485 ... Which, in theory is the maximum result I can get...
But wait, this is millirads so the maximum angle I can measue is... just over 1.6 full rotations...
Oops... Either I did my math wrong, or I have to reduce my update rate.
In fact, this does reflect what I see in my log data... after getting to 10485 mRad, the angle starts counting down again...
So I need to reduce my ADC range/rate, or reduce my measurement accuracy (like changing to tenth of a degree.)
No wonder my bot corrected in the wrong direction on evey second lap
Phil Malone
http://www.GEARSinc.org
  #287   Spotlight this post!
Unread 24-01-2008, 13:49
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Just to make sure we didn't have odd problems like this, our code looked something like
void Read_Yaw(void) {
  phi=Get_Gyro_Angle();
  phi=phi%6283L;  // Avoid unneccesary wraparound
  #288   Spotlight this post!
Unread 24-01-2008, 16:38
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Well, you have to assume something is gonna break if you do enough loop de loops .
-Kevin
Kevin Watson
http://kevin.org
  #289   Spotlight this post!
Unread 24-01-2008, 18:21
cdennisxlx2's Avatar
cdennisxlx2 cdennisxlx2 is offline
Team San Diego Web Liaison
AKA: Cameron Dennis
FRC #1266 (The Devil Duckies)
cdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to behold
Exclamation Re: New C18 3.0+ Compatible FRC Code
Sorry if this has been addressed before I don’t have time to go through all 288 posts but we are having an issue when we compile. Here is what our output looks like, if anyone can help it would be greatly appreciated. Thank you
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\FRC2008\2008 Code\ifi_frc_simple_30\ifi_frc.mcs".
Clean: Done.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "autonomous.c" -fo="autonomous.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\FRC2008\2008 Code\ifi_frc_simple_30\ifi_frc.h:31:Error [1027] unable to locate 'p18cxxx.h'
C:\FRC2008\2008 Code\ifi_frc_simple_30\serial_ports.h:48:Error [1027] unable to locate 'stdio.h'
Halting build on first failure as requested.
BUILD FAILED: Thu Jan 24 15:12:09 2008
Team San Diego Robotics Web Liaison
Webmaster and Technical Advisor for the San Diego Regional Planning Committee.
Official Score Keeper for the San Diego Regional
www.sandiegoregional.com
www.frc1266.com
  #290   Spotlight this post!
Unread 24-01-2008, 20:17
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
You need to go to the project menu then build options then project
On the directory tab select Header Search Path (i dont have mplab infront of me right now but it is the header one), create a new one that points to the mcc18\include folder where ever that may be, it might be in C:\Program Files\ or just under C:\
Seeing as that variable is off you may also need to set the Library Search Path to mcc18\lib folder
A2D Solving the Imaginary Error Function...
  #291   Spotlight this post!
Unread 24-01-2008, 20:23
FRC #2429
Clean: Done.
It looks like MPLAB doesn't know where to find the C18 header files (it seems to me that if you just sneeze while MPLAB is running, it'll forget all kinds of vital information <grin>). Anyway, go to Project > Build Options > Directories tab > Include Search Path and then point it to c:\mcc18\h.
-Kevin
Kevin Watson
http://kevin.org
  #292   Spotlight this post!
Unread 24-01-2008, 21:22
FRC #2429
Originally Posted by Manoel View Post
Would it be too much to ask for an updated library for the EDU-RC?
Yes, at some point I'll port code to the EDU-RC (and maybe Vex too).
-Kevin
Kevin Watson
http://kevin.org
  #293   Spotlight this post!
Unread 24-01-2008, 22:16
AKA: Cameron Dennis
-Kevin
well my first errors are gone but now i get these...
Clean: Done.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722  /i"C:\mcc18\h" "autonomous.c" -fo="autonomous.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722  /i"C:\mcc18\h" "disabled.c" -fo="disabled.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722  /i"C:\mcc18\h" "ifi_code.c" -fo="ifi_code.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722  /i"C:\mcc18\h" "ifi_frc.c" -fo="ifi_frc.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722  /i"C:\mcc18\h" "interrupts.c" -fo="interrupts.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722  /i"C:\mcc18\h" "pwm.c" -fo="pwm.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722  /i"C:\mcc18\h" "serial_ports.c" -fo="serial_ports.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722  /i"C:\mcc18\h" "teleop.c" -fo="teleop.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\FRC2008\2008 Code\ifi_frc_simple_30\teleop.c:105:Warning [2066] type qualifier mismatch in assignment
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722  /i"C:\mcc18\h" "timers.c" -fo="timers.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mplink.exe" /l"C:\Program Files\microchip\mcc18\lib" "C:\FRC2008\2008 Code\ifi_frc_simple_30\18f8722.lkr" "C:\FRC2008\2008 Code\ifi_frc_simple_30\autonomous.o" "C:\FRC2008\2008 Code\ifi_frc_simple_30\disabled.o" "C:\FRC2008\2008 Code\ifi_frc_simple_30\ifi_code.o" "C:\FRC2008\2008 Code\ifi_frc_simple_30\ifi_frc.o" "C:\FRC2008\2008 Code\ifi_frc_simple_30\interrupts.o" "C:\FRC2008\2008 Code\ifi_frc_simple_30\pwm.o" "C:\FRC2008\2008 Code\ifi_frc_simple_30\serial_ports.o" "C:\FRC2008\2008 Code\ifi_frc_simple_30\teleop.o" "C:\FRC2008\2008 Code\ifi_frc_simple_30\timers.o" "C:\FRC2008\2008 Code\ifi_frc_simple_30\ifi_frc_8722.lib" /m"ifi_frc.map" /w /o"ifi_frc.cof"
MPLINK 4.1, Linker
Copyright (c) 2006 Microchip Technology Inc.
Error - could not find file 'clib.lib'.
Errors    : 1
Link step failed.
BUILD FAILED: Thu Jan 24 19:11:44 2008
www.frc1266.com
  #294   Spotlight this post!
Unread 25-01-2008, 00:53
FRC #2429
The first warning can be eliminated by changing the memory model to large: Project > Build Options > MPLAB C18 tab > Catagories: Memory Model > select large model for code and data.
The clib.lib error is due to MPLAB not knowing where your compiler libraries are installed: Project > Build Options > Directories tab > Library Search Path
-Kevin
Kevin Watson
http://kevin.org
  #295   Spotlight this post!
Unread 25-01-2008, 01:05
AKA: Cameron Dennis
Talking Re: New C18 3.0+ Compatible FRC Code
cool, it all works now, thank you very much
www.frc1266.com
  #296   Spotlight this post!
Unread 25-01-2008, 02:58
FRC #2429
Just FYI, I believe that I have a single version of the code that will work with all robot controllers from 2004 on and can be built with C18 2.4 or 3.1. After seeing if I can improve the gyro integration code (per Philbot's posting above), doing some additional testing, and writing a bit more documentation, I should be able to release the code in the next few days.
-Kevin
Kevin Watson
http://kevin.org
  #297   Spotlight this post!
Unread 25-01-2008, 10:05
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
-Kevin
Kevin,
You truly are an example that all FIRSTers can look to, including myself. Thank you for your incredible efforts!!
  #298   Spotlight this post!
Unread 25-01-2008, 20:20
stevethetinker stevethetinker is offline
FRC #1288 (RAVEN)
stevethetinker is an unknown quantity at this point
I do like the new code layout. I would like to see the code for C18 2.4. We do prototyping on previous years' robots and having both 3.15 and 2.4 on our machines seems a bit difficult to manage.
  #299   Spotlight this post!
Unread 26-01-2008, 17:26
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Kevin,
Now finding that the RC is stuck in Programming Mode at the end of download if adc is initialized.......any suggestions? (I did read the readmes!!!)
Jon Mittelman
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
  #300   Spotlight this post!
Unread 26-01-2008, 18:28
1jbinder 1jbinder is offline
FRC #0852
1jbinder is an unknown quantity at this point
Hi Kevin,
We keep on getting a error that ADC_CH0 is not defined. This happens when we try to use rc_ana_in_01. We looked in all of the header files including the complier file and could not find the definition but it is clearly used in ifi_frc.h.This might be a stupid error but please can someone help us.
Thanks,
Julan
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
