Go to Post You should qualify the same way you eliminate if you ask me. - sircedric4 [more]
Unread 24-01-2008, 20:23
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Re: New C18 3.0+ Compatible FRC Code
Originally Posted by ghhs_1527 View Post
Sorry if this has been addressed before I don’t have time to go through all 288 posts but we are having an issue when we compile. Here is what our output looks like, if anyone can help it would be greatly appreciated. Thank you
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\FRC2008\2008 Code\ifi_frc_simple_30\ifi_frc.mcs".
Clean: Done.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "autonomous.c" -fo="autonomous.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\FRC2008\2008 Code\ifi_frc_simple_30\ifi_frc.h:31:Error [1027] unable to locate 'p18cxxx.h'
C:\FRC2008\2008 Code\ifi_frc_simple_30\serial_ports.h:48:Error [1027] unable to locate 'stdio.h'
Halting build on first failure as requested.
BUILD FAILED: Thu Jan 24 15:12:09 2008
It looks like MPLAB doesn't know where to find the C18 header files (it seems to me that if you just sneeze while MPLAB is running, it'll forget all kinds of vital information <grin>). Anyway, go to Project > Build Options > Directories tab > Include Search Path and then point it to c:\mcc18\h.
-Kevin
Kevin Watson
http://kevin.org
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
