Go to Post Q: "What does your robot do?" A: "It collects data about the surrounding environment, then discards it and drives into walls" - tsaksa [more]
Unread 24-01-2008, 20:52
program1's Avatar
program1 program1 is offline
AKA: RJ
FRC #2441
program1 will become famous soon enough
How to use the keyang motor
ok so were new to the FIRST Competition so we want to know if anyone have a idea on what to do with the Keyang motor?
Unread 24-01-2008, 22:42
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: How to use the keyang motor
You can do whatever you want with it! Seriously it's nice because of the worm gear which resists back driving. Imagine if you were rotating some part of your arm in the air then wanted to stop (motor off), the worm gear keeps it from falling back down. Look in your KOP for some plastic hubs. One of them will fit your Keyang motor. You should have two with different tooth counts with a hub that fits each. Use your imagination on how to utilize it!
Keyang Motor? RoboGeek99 General Forum 2 18-01-2008 15:58
Keyang motor - how do you tell L or R Andy Baker Technical Discussion 4 18-07-2007 19:44
2 motor adapter and keyang motor dimensions Bruno Estevão General Forum 1 16-02-2007 09:36
keyang motor wedellm Motors 2 14-02-2007 02:37
Keyang Motor Model aviv Inventor 5 05-02-2007 21:56
