Go to Post We make ourselves better by lifting others and standing on their shoulders, not by knocking them down. - Taylor [more]
Unread 24-01-2008, 21:07
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
Re: Ultrasonic rangefinder code
Originally Posted by Andy Goetz View Post
If you do the algebra, with the Maxsonar, you can just divide the incoming value by two to get the distance in inches.
Well you can do that, if you don't mind the small error that is introduced from it, and that the version of the sensor uses 10mV per inch scaling. All the newer models use 9.8mV per inch scaling so your range readings will be off even more.
For example a reading of 512 would be 2.5mV which is very close the 2.55mV maximum range that this device uses. So dividing by 2 would give you 256, which is close to 250 inches the device is reporting, but 6 inches off at that range(using 10mV inch). As you get closer it becomes less of an issue.
It all depends on the level of precision you need or want.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
SRF04 Ultrasonic Rangefinder Unresponsive the401tauntaun Programming 10 20-01-2008 12:39
Ultrasonic will not work with another Ultrasonic plz help Jackel148 Programming 10 10-05-2006 15:31
Ultrasonic Distances irishninja FIRST Tech Challenge 1 30-04-2006 20:25
Programming Parallax Ultrasonic Rangefinder edman Programming 2 17-02-2006 08:35
Ultrasonic Rangefinder Operating On I2C Bus CapnBFG Electrical 10 04-06-2005 01:31
