| Thread Tools |
Rating:
Display Modes |
#76
Re: Can the Plane Take-Off?
Yeah, I got Mythbusters confused with Smash Lab, so 9 EST/Pacific.
#77
Re: stolen from another forum
Yes.
#78
The plane could take off. Planes do not put any force into the wheels when it taxis. It moves the same way it does in the air, prop or jet. Due to inertia you could say the plane would stay in the same position relative a third stationary observer. the conveyer belt could move back and forth rapidly and the plane would still stay still. All the wheels do is just keep the plane from falling and give it support when it has 0 lift. If you turn on the prop the plane would move foward, it doesnt matter at all what the conveyer belt does, the only force it can put on the plane is up. If you had a converyer belt long enought he plane would take off for it would be moving compared to the 3rd stationary oberserver. The only way it would not work is if the conveyer belt was not long enough or there was a strong tail wind. but a plane can not take off without a conveyer belt in thos conditions.
#79
The key to this puzzle is the statement in the initial conditions "This conveyer has a control system that tracks the plane speed and tunes the speed of the conveyer to be exactly the same (but in the opposite direction)." As soon as the thrust of the engine pushes the plane forward some small distance (thus it has some speed), the conveyer moves at whatever speed necessary to counteract that speed. It can move at any speed! So, the force on the plane from the belt is limited by the friction of the wheel bearings. Move that belt at a high enough speed (a fraction of lightspeed, for example) and the force transmitted to the aircraft through the freely rolling wheels will be enough to counteract the force of the engine. By definition, the plane cannot move because the belt is free to move at any speed, and while the rolling wheels don't transmit a lot of force to the airframe, the force is nonzero and therefore you must account for it. Oh, in a real, practical world, you are correct: The plane will move before the belt can reach 0.1c. But, that wasn't the puzzle question... Don |
#80
Cool, this would make for a very fun team debate ![]() thanks, Vivek |
#81
The condition says that the speed of the conveyor is (effectively) the negative of the speed of the airplane. It does not say that the conveyor goes fast enough to stop the plane with friction. It does not say that the conveyor is attached to the wings or tail (which would be necessary to stop the plane from taking off unless the brakes were on). All it says is that the conveyor moves at the same speed as the plane in the opposite direction. That said, guess who's going to be watching Mythbusters next Wednesday if at all possible? |
#82
Take the example (as he did) of an arrow shot from a bow. It is understood that the arrow exists, and takes up space, and at every infinitessimal instant, has a known position. Since positions are absolute and immobile (as measured from your frame of reference, i.e. the earth's rotation), the arrow does not move because at any given freeze-frame moment it is in a given position & orientation and therefore it is still. We all know this is not true, otherwise Robin Hood would have been out of a job. But, as Zeno endeavored to prove, it does show the fallability of human logic. There are many more instances that recall this notion (Heraclitus saying one can never step in the same river twice, and the completely ridiculous "if a tree falls...." nonargument) that show that logic can be used to prove (or disprove) nearly anything. To discuss the notion of a giant fan producing lift (or "suck") to the plane, this would be a colossal mistake. As soon as the plane leaves the wind chute provided by the fan, it would enter the (relatively) still airmass and fall back down, either tilting back each time and eventually reaching a stall or resulting in a nosedive. Last edited by Taylor : 01-25-2008 at 12:16 PM. Reason: big fan |
#83
The plane can take off. The thrust is not relative to the speed of the wheels turning. The plane will move forward regardless of how fast its wheels are turning, the thrust is not going into the wheels. The question is basically flawed in making you think that because the conveyor belt is moving at the same speed as the wheels that the conveyor could hold back the thrust/forward movement of the plane. To believe that the plane can not take off, you would also have to believe that if the conveyor belt was moving the wheels at the same speed the plane needs for take off, the plane would fly without its engine on. In order for the conveyor belt to stay under the plane once the thrust is enough for take off, the conveyor had better be moving pretty fast in relation to the ground if it wants to stay underneath the plane. The conveyor can not put enough force into free spining wheels to hold back the thrust of the planes engine.
EDIT: The plane does not move forward and take off because the wheels are turning, the wheels turn because the plane is moving and the wheels turning do not make the plane take off. The question is flawed. Last edited by ALIBI : 01-25-2008 at 12:43 PM. |
#84
I love this question.
See attached Image. -Oris- |
#85
I see that both sides have good reasons, however in theory I believe that it would not take off. IF the conditions were exactly as stated, then it would be impossible for the plane to move relative to the air. And that relativity is the important part. Oh well, I guess we will all see come Wednesday. However, I guarantee you that no matter how MythBusters recreates this somebody will not agree with their conditions and will therefore claim the results void.
#86
For the record, if I had a long enough conveyor belt, I would probably be able to test it. The rig would be the problem, but I can almost guarantee you I could get a plane off the ground under the experiment conditions. |
#87
The original post: "A plane is standing on a runway that can move (some sort of band conveyer). The plane moves in one direction, while the conveyer moves in the opposite direction. This conveyer has a control system that tracks the plane speed and tunes the speed of the conveyer to be exactly the same (but in the opposite direction). The question is: Will the plane take off or not? Will it be able to run up and take off?" The formula: The vest way to track the speed of the plane would be to find the C=circumference of the wheels R=# of rotations of the wheel T=time the wheel takes to rotate that # of times S=Speed of plane=Speed of conveyer belt S=(C X R)/T Now, let's take this one step at a time. The plane is stopped. The conveyer belt is stopped. The plane starts to move and the conveyer belt INSTANTANEOUSLY starts to move in the opposite direction. (remember this is all in theory with ideal conditions) As the plane speeds up to the speed necessary to take off, the conveyer belt does the same in the opposite direction. Now, with these conditions, it is impossible. To truly put this to rest, the conditions would have to be more clearly stated in the question. For instance, how does it track the planes speed? That is rather critical. Do we ignore friction? As some have posted in the past, what about wear and tear? I think that interpretation is the true decider on this one. I am positive that with the conditions in my mind, I am right. I am positive that with the conditions in your head, you are right. The thing is that the conditions were not clearly stated to the original post and thus we have no choice to say that either outcome is possible depending on how it is interpreted. P.S. I hope that if you do not understand my statement on the interpretation of the problem, then we can just agree to disagree. Also, sorry for the long post. |
#88
It took me a while to get my head wrapped around that notion, but once I did, this problem became very simple. |
#89
Again, not to beat a dead horse, but the fact that rolling frition and static friction both depend on normal force makes this question possible to answer. Regardless of the speed that the airplane moves [and thus the conveyor belt] the force exerted by the wheels on the aircraft is constant (Except that it will be marginally higher initially to go from static to kinetic friction). Unless this constant is so large that the aircraft cannot take off under normal circumstances, the aircraft will take off. Now to argue the other extreme: As mentioned earlier in this thread, assuming the experiment conditions make it such that the aircraft cannot move, due to viscosity effects in the air immediately above the treadmill, the treadmill drags some of the air along with it. This boundary layer increases in thickness with increasing velocity, and so at some speed of the treadmill, the wing will experience enough relative air velocity to produce lift. At this point, it will lift the aircraft off of the ground. Now it may be argued that the treadmill now stops, the aircraft drops to the gound, repeat ad infinitum, or that the aircraft will then gain enough airspeed to then transition to full forward flight. In either case, the airplane has lifted off the ground, technically a takeoff. Thus the aircraft will lift off regardless of any of the conditions in the problem statement. Last edited by lemon1324 : 01-27-2008 at 12:52 AM. |
| air speed sensor for rc plane | Greg Needel | Technical Discussion | 19 | 10-07-2005 11:43 PM |
| Breaking the plane | kevinw | Rules/Strategy | 16 | 03-28-2005 11:06 AM |
| pic: It's a bird.. It's a plane.. It's the 573 Mech Warrior bot! | Lisa Perez | Robot Showcase | 3 | 02-27-2005 03:09 PM |
| NASCAR, Hendrick owned plane crashed | Bcahn836 | Chit-Chat | 12 | 11-06-2004 08:59 AM |
