Re: mounting accelerometers & gyros
Certainly non-conductive materials!
In the past we have mounted gyros and accelerometers with screws and nuts onto a thin (<1/16") metal plate, with a thin (1/8") piece of hobby foam sandwiched underneath. The screws were not too tight (so the solder points below didn't punch through the foam), then we used blue thread-locker to make sure it stayed. The metal plates were then mounted to the robot frame as necessary. Don |
Thanks for the input Don. I have them mounted with a rubber washer dampening the vibrations. I'll let you know how it works out.
| Gyros | EROCK | Kit & Additional Hardware | 10 | 21-01-2008 18:58 |
| Where to get the KOP accelerometers? | Billfred | Kit & Additional Hardware | 0 | 19-11-2005 10:15 |
| The accelerometers | Validius | Programming | 9 | 21-03-2005 08:22 |
| pic: The Bobcats 2001 & 2003 & Admirers | CD47-Bot | Robot Showcase | 19 | 28-02-2004 12:36 |
| Gyros!! | RAWdealer59 | Programming | 1 | 12-02-2003 16:46 |
