Go to Post If all you have to say are demeaning and vile comments, then shut your trap and keep it to yourself. - Ryan Dognaux [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:45
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Not heat sinks...
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Posted on 1/22/2000 4:21 AM MST
In Reply to: heat sinks posted by James Jones on 1/21/2000 1:42 PM MST:
Those are not heat sinks.
They are used to change the magnetic field of the permanent magnets in the motor. They can improve the output of the motor by 10-20% (depending on the particulars of the motor & magnets).
Anyway, I would not recommend that you remove them.
Joe J.
[IMG] code is Off
can motors be modified ronnie_82 Motors 37 07-01-2003 08:09
'IT' info... archiver 2001 19 24-06-2002 01:58
New IT info? Mike Soukup Dean Kamen's Inventions 10 08-12-2001 23:03
Heat sinks Tech Fusion Off-Season Events 2 11-11-2001 19:57
heat gun Lake Orion OCCRA 2 21-10-2001 23:34
