Go to Post There's no crying in robotics! - TubaMorg [more]
Unread 24-01-2008, 15:23
dtengineering's Avatar
AKA: Jason Brett
Launcher Safety Ideas
It looks like we've got quite a few teams who are going to be launching the ball this year. Hopefully we will be one of them. Our initial tests are quite promising.
Since launching the ball requires some significant accelleration/velocity/momentum there is a potential safety hazard, and it seems like a good idea to share some ideas on what might be done to make a launch mechanism as safe as possible. Here's a couple that we've come up with, and I'm throwing them out for comments additions, etc.
1: Keep high velocity moving parts within the starting configuration of the robot.
2: Reduce the potential for accidental launches by having a "safety" button on the OI, so that the driver/co-driver has to press and hold the safety button, and then pull the launch trigger in order to make the ball launcher fire.
3: Have sensors (IR object detectors, the Sharp GP series for example, but simple switches would do) detect whether the trackball is in place before allowing a launch. (Prevents "dry fires" plus having the ball in place means that it is likely that no one's head is in the way of the launcher.. or even within 20" of it!)
4: Have the system automatically and gradually power down when the control signal is lost (end of match, OI unplugged, etc.). For pneumatics this can be done simply by choosing the correct valve setup. For spring loaded systems this may be more difficult to do automatically, but at the very least a safe and simple unloading process should be designed in to the system.
5: Warning lights on the robot to indicate when the system is "armed".
6: Your ideas....
And, the usual caveat... even if a team or tech inspector posts something here and you implement it on your robot, the definition of "safe" is still the prudent judgement of the tech inspection team at your regional event. CD is not the rule book! These are just some ideas that might help... because it's much easier to build safety in to a system than to add it on a Thursday at a regional.
Jason
Unread 24-01-2008, 16:00
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Launcher Safety Ideas
All systems that store energy should release that energy slowly when the robot is powered down, but before anyone has a chance to get onto the field and near the robot. By this I mean dissapate the energy over 2-5 seconds.
This means:
1> Pneumatic systems should dump pressure to atmosphere when powered down.
2> Spring loaded and latched systems should unlatch / disengage and dissapate the energy slowly (over a couple of seconds).
3> Winches should release and allow unspooling (especially if used to deform objects to gain spring tension) slowly.
3> Pinch points need to be minimized (watch those 4 bar arms and sissor lifts) while lifting devices are powered down.
Teams should be able to demonstrate these safety measures to an inspector while in the pits. So while just unlatching springs may be safe on the playing field, it may not be safe in the pits.
___________________
- Tennyson, Ulysses
Unread 24-01-2008, 19:19
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
I would like to point out that while this is a very good idea, the safety of the robot relies completely on the software not malfunctioning (When does that ever happen... )
All of you launching teams may want to try to implement some sort of physical failsafe that prevents the catapult from firing unless a ball is present. Maybe something like in the cheesy drawing I attached: A lever that is easy for the ball to push out of the way, but it is otherwise in the way of the catapult arm from firing. This would prevent the catapult from doing a 'dry fire' if the main latch fails for some reason.
Unread 25-01-2008, 00:17
Racer26 Racer26 is offline
Also, I think it goes without saying that any edges should be very rounded and preferably most of the hard parts of the catapult mechanism somehow padded such that in the event of it contacting a team member while in motion it doesn't cause too much damage.
In addition, efforts should be made that the systems be as harmless as possible when the robot is not energized. Perhaps having your spring pack connected to the rest of the system with a carabiner. Non-spring based systems should by default generally be fairly harmless when not powered. Just remember to watch when evacuating the air system of the direction things could move. I have been hit by moving parts before.
Unread 25-01-2008, 01:14
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
I'd suggest putting a couple signs on the robot. Something along the lines of "DANGER, SPRING LOADED MECHANISM. DISCHARGE BEFORE INSPECTION OR SERVICING. KEEP CLEAR AT ALL TIMES."
Safeties are great, but you should also warn people that the thing they are looking at is, in fact, a launcher and not some other mechanism.
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
Unread 25-01-2008, 01:58
CraigHickman
Posts: n/a
We're following the Battlebots rules for our launcher. That means hardware stops in position, removed when the match is about to start. All pinch joints will be brightly colored, and we're having a new position in the pits: Fire Commander, whose job it is to make sure the firing path is clear during testing.
Very good thread.
Unread 25-01-2008, 07:45
For those teams that may be using pneumatics, please be careful in your design. Far too often, a team will design the control system such that at "power on" some part of the robot will extend as the air pressure builds up. This is usually a big surprise to an inspector or other visitor, who may be checking for something inside the robot. Robots parts should not move until told to do so.
Unread 25-01-2008, 08:22
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Al, could you please help us figure out how to do that? Would it be sensible to use the magnetic sensors for the cylinders to "tell" the RC what position they are in, and switch the solenoid valve to that position at power on?
Unread 25-01-2008, 08:32
Gdeaver Gdeaver is offline
FRC #1640
For those teams that are launching from the floor with those nice big arching trajectories, The amount of potential energy you are storing is not safe. The whole mechanism Is un-safe. Nothing you can do will make it "safe". All you can do is implement strategies that minimize the risk of injury if the mechanism fails. The question is can you lower the risk of injury to the point that you and the robot inspectors have a subjective opinion that the risk is acceptable.
Unread 25-01-2008, 08:59
Jim,
It is usually a simple matter of knowing how the solenoid reacts at power on and making that default position be the "parked" position for actuators. Many times, teams do not take the time to distiguish that. If the action does not cause a robot part to extend out of the sizing box no change is made in the design process. Parts should not move until enabled.
Unread 25-01-2008, 09:04
MrForbes's Avatar
AKA: Jim
That will work if we make sure to always "park" the mechanism before powering on the robot.
One concern we have with this concept is that this would cause the mechanism to park itself at power off, which could cause unexpected actions for those not familiar with the robot. It would be nice if the robot would just sit there when we kill the power.
Unread 25-01-2008, 10:34
t-raum's Avatar
t-raum t-raum is offline
AKA: Jeremy Traum
FRC #1625 (Winnovation)
t-raum is an unknown quantity at this point
Send a message via AIM to t-raum
Our team plans on launching the ball. To help with safety in the pits and on the field we plan to make a safety latch that goes over our mechanism to prevent injury. We also plan release the energy in the system after the plate has been on without dry firing it.
The main thing that will help stop accidents in the pits and on the field is the fact that everyone working on the robot or in close proxcimity to it should know that it could potentially go off and take every action to ensure that this does not happen. This involves knowing where your team members are and making sure that innocent bystanders are told they need to get away from your launching device so they do not get hurt. You can tell them to admire at a distance until you are sure the system is safe.
T-raum
Unread 25-01-2008, 10:41
MrForbes's Avatar
AKA: Jim
We are taking a different approach. As Gdeaver says, a mechanism that can store energy and quickly release is a dangerous thing, and we felt that relying on interlocks and safety procedures is not adequate. So, we designed our mechanism to behave like any other pneumatic actuated device when the ball is not loaded into it (ie. it moves slowly), and to act like a ball launcher only when the ball is in place.
I think it would be difficult to do this with any mechanism that uses springs.
And any mechanism that has a latch (or two or three or...) that suddenly releases a spring loaded bar is intrinsically dangerous.
Unread 25-01-2008, 10:50
SSMike's Avatar
SSMike SSMike is offline
The Guy with the Big Blue Two
FRC #0250 (The Dynamos)
Team Role: Operator
SSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond repute
I'd like to add that any team that is considering a launching mechanism should make sure that they have proper practice as to working the launcher. Like it was said above, the last thing that you want is for your launcher to go off when an inspector, team member, or bystander is too close.
That being said, I would like to remind everyone to try your best to control not only when you launch the ball, but where. Obviously, no one should (and I hope no one would) ever try to aim at another robot. First off it is a penalty, and second it just unsportsmanlike. While accidents happen, please try your best to minimize them by launching so that another robot will not be damaged.
--Mike
Long Live #4
Just when I find the key to success, someone goes and changes all the locks.
"It's kind of fun to do the impossible" -Walt Disney
When you put 'THE' and 'IRS' together, it forms 'THEIRS'. Coincidence? I think not!
Why is the name of the phobia for the fear of long words: hippopotomonstrosesquippedaliophobia?
"There's no such thing as a winnable war......." Bring our Troops Home
I will never let you fall
I'll stand up with you forever
I'll be there for you through it all
Even if saving you sends me to heaven
--The Red Jumpsuit Apparatus
Unread 25-01-2008, 19:35
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
IMHO safety features on the robot during competition only slow us down....or do they? personally, and not to sound arrogant or "holier-than-thou-art", but in my experience stuff like needing to press 2 buttons to fire, power-down procedures, etc. are over redundant and not needed. when we demonstrate the robot anywhere, yes, we do have as many safety systems as possible, but not usually during the competiton......just my 2 cents....
PS
i guess i'm refering more to having a killswitch and stuff more like that, that is, software safety features. Hardware safety features are a must though
safety ideas zakk General Forum 13 18-11-2007 22:36
Can launcher Dick Linn Chit-Chat 3 28-02-2007 18:47
Safety Ideas Zero-Bee Technical Discussion 10 03-02-2007 12:37
[OCCRA]: HP Launcher Silent_Stryker OCCRA Q&A 1 12-09-2006 16:33
pic: LAUNCHER CD47-Bot Chit-Chat 9 11-11-2003 22:11
