Go to Post If you want to change the culture sometimes you need to change a little yourself - Koko Ed [more]
Unread 24-01-2008, 20:28
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
pic: 1178 New Drive Train
Unread 24-01-2008, 20:30
bmusser bmusser is offline
Brian Musser
FRC #1504 (Desperate Penguins)
bmusser has a spectacular aura aboutbmusser has a spectacular aura aboutbmusser has a spectacular aura about
Re: pic: 1178 New Drive Train
The only thing that I can see is you are taking engagement away from your sprocket. Usually you would tension so that you are getting more chain wrap on the sprocket. I don't think it will be a problem though.
Unread 25-01-2008, 00:18
void* Jake;
FRC #1178 (DURT)
True. With the springs we're using, though they don't like like much, the chain has almost no give. I, also, doubt that'll be a problem in this case.
void function(void)
  function();
Unread 25-01-2008, 02:33
scottyh2006's Avatar
scottyh2006 scottyh2006 is offline
AKA: Elmo (and what you gonna do about it)
FRC #0564 (Ditigal Impact)
scottyh2006 is on a distinguished road
those wheels were a pain in the a$$ to make
Good Luck to all
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
pic: Toltechs drive-train teaser Andrew Schuetze Robot Showcase 21 06-02-2006 13:27
pic: 1493 Drive Train 1 Dan-o Robot Showcase 15 17-02-2005 14:59
pic: 350 drive train CD47-Bot Robot Showcase 4 16-02-2004 00:05
pic: 311's Drive Train CD47-Bot Robot Showcase 2 24-02-2003 18:09
