Go to Post Earlier this week it took me a little bit too long to realize that the reason my pen wasn't writing correctly was that it was actually a screwdriver. I'm going to have to ask for a few nights of honest sleep before signing off on a report. - EricVanWyk [more]
Unread 23-01-2008, 18:04
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
Ultrasonic rangefinder code
Hi, I'm looking for code that might already be written to obtain a distance from an ultrasonic rangefinder. The one in specific that I have is at the following link.
http://www.acroname.com/robotics/parts/R271-SRF05.html
I could write the code myself, but I would rather see what is already out there so that I don't need to make the same mistakes that others have gone through.
Thanks much!
Unread 23-01-2008, 18:20
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Re: Ultrasonic rangefinder code
WPI Lib has very good sensor code, including code for ultrasonic sensors. For details, look at the WPI Lib documentation.
WPI Lib is basically an extended version of the library used in EasyC.
Unread 23-01-2008, 18:29
FRC #2477
What if I don't use EasyC? Will the code still work?
Thanks!
Unread 23-01-2008, 20:14
JonathanLKS JonathanLKS is offline
Code::Blocks
FRC #0610 (The Coyotes)
JonathanLKS will become famous soon enough
Send a message via MSN to JonathanLKS
WPILib will work without EasyC, though I don't think it'll work with any of Kevin's code if your using that as well.
Team 610 [ Co-Leader | Head Programmer | Webmaster ]
We're attending: Greater Toronto Regional, San Diego Regional, Championship
Unread 23-01-2008, 20:23
in between teams
AKA: Luke Van Oort
If you are willing to try a different ultrasonic, the MaxBotix one requires practically no coding at all; it can output distance as an analog signal, which requires no interrupts, and all you need to do is read from an analog input. The two ultrasonics cost about the same too ($0.45 difference).
Team 1219: 2009 - Mentor
Unread 23-01-2008, 21:22
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
We aren't using EasyC or WPILIB, but we have used the Maxbotic sensor using analog with good results. The current models use a 9.8mV to an inch scaling.
The code was simple as well.
Here's a sample for it that I just typed from memory using analog port 1:
unsigned int sonic;
unsigned int mV;
unsigned int inches;
sonic = Get_Analog_Value(rc_ana_01);
mV =( (sonic * 5000) / 1024 );
inches = mV * 10 / 98;
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 24-01-2008, 18:19
Andy Goetz Andy Goetz is offline
Team Captain
FRC #2898 (The Flying Hedgehogs)
Andy Goetz is on a distinguished road
If you do the algebra, with the Maxsonar, you can just divide the incoming value by two to get the distance in inches.
Unread 24-01-2008, 18:53
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Andy, that depends on a lot of things and isn't necessarily true.
On ours, using Kevin's ADC code, we have to devide by 3.933, or multiple by 100/393 to get inches.
Unread 24-01-2008, 21:07
Phalanx's Avatar
Well you can do that, if you don't mind the small error that is introduced from it, and that the version of the sensor uses 10mV per inch scaling. All the newer models use 9.8mV per inch scaling so your range readings will be off even more.
For example a reading of 512 would be 2.5mV which is very close the 2.55mV maximum range that this device uses. So dividing by 2 would give you 256, which is close to 250 inches the device is reporting, but 6 inches off at that range(using 10mV inch). As you get closer it becomes less of an issue.
It all depends on the level of precision you need or want.
Unread 25-01-2008, 00:37
There's no particular reason for the software to deal with distance in inches, or centimeters, or any "engineering" unit. We've usually done all the navigation using the equivalent of raw encoder or analog input counts.
For something like autonomous scripting we typically convert in the other direction, to turn familiar units like inches into the values the program likes.
SRF04 Ultrasonic Rangefinder Unresponsive the401tauntaun Programming 10 20-01-2008 12:39
Ultrasonic will not work with another Ultrasonic plz help Jackel148 Programming 10 10-05-2006 15:31
Ultrasonic Distances irishninja FIRST Tech Challenge 1 30-04-2006 20:25
Programming Parallax Ultrasonic Rangefinder edman Programming 2 17-02-2006 08:35
Ultrasonic Rangefinder Operating On I2C Bus CapnBFG Electrical 10 04-06-2005 01:31
