Go to Post FIRST - Breaking stereotypes everywhere - Sparks333 [more]
Unread 17-01-2008, 19:17
itsnotabigtruck itsnotabigtruck is offline
FRC #2002 (TETRA)
itsnotabigtruck is on a distinguished road
Visual Studio C18/MPLINK build rules >>>HERE<<<
I got tired of having to use MPLAB, and didn't want to install Eclipse (already had VS), so I wrote this build rules file in order to use VC to compile for the IFI RC.
This is very, very beta, and I am not responsible if it fries your robot, fries your computer, kills your dog, burns your house, etc.
Visual Studio MCC18 build rules file (right-click and choose Save Link As to download)
In order to use this:
  1. Create a Visual C++ project, preferably close to the root of the drive.
  2. Put mcc18.rules in your project directory
  3. Right-click the project in Solution Explorer and select Custom Build Rules
  4. Click Find Existing and find the mcc18.rules you put in the project directory
  5. Click No if you get asked whether you want to add the directory you chose to the build rules search path
  6. Click OK
  7. Right-click the project again and select Tool Build Order
  8. Check Microchip C18 C Compiler and Microchip MPLINK Linker, and uncheck everything else
  9. Click OK
  10. Right-click the project again and select Properties
  11. Select Microchip C18 C Compiler, then General
  12. Set these options:
    • Compiler Memory Model: Large
    • Target Processor: 18F8722
    • Additional Macros: _DONT_USE_TMR0;_LARGE_CODE;_FRC_BOARD
    • Suppress Warnings: 2066
  13. Then go to Optimization, and set more options (note that you probably don't need to turn off all of these optimizations, they're just the settings from the default code):
    • Disable Unreachable Code Removal: Yes (-Ou-)
    • Disable Tail Merging: Yes (-Ot-)
    • Disable Branch Optimization: Yes (-Ob-)
    • Disable Dead Code Removal: Yes (-Od-)
    • Disable Procedural Abstraction: Yes (-Opa-)
    • Disable Copy Propagation: Yes (-Op-)
    • Disable Redundant Store Elimination: Yes (-Or-)
  14. You might also want to set Default Char Unsigned to Yes (-k)
  15. Now go to Microchip MPLINK Linker and set these options:
    • Linker Script Search Path: $(ProjectDir) (in most cases)
    • Output HEX File Type: INHX32
    • Suppress .COD and .LST File Creation: Yes (/w)
    • Additional Input Files: 18F8722.lkr (if you're using the default IFI linker script)
  16. Now go to General under Configuration Properties
  17. Set Output Directory to Debug\bin (or somewhere else, if you prefer)
  18. Set Intermediate Directory to Debug\obj (or somewhere else, if you prefer)
  19. Set Extensions to Delete on Clean to "$(IntDir)\*;$(OutDir)\*.out;$(OutDir)\*.hex;$(Out Dir)\*.hxh;$(OutDir)\*.hxl;*.o" (no quotes)
  20. Set Configuration Type to Utility
  21. Click OK
  22. Copy all your code to the project folder
  23. Click the Show All Files button in Solution Explorer
  24. Select all your headers, C files, object libraries, and linker scripts (note: only include libraries and linker scripts for the 8722)
  25. Right-click them and select Include in Project
  26. Hit F6
  27. You're done!
Unread 17-01-2008, 21:01
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Visual Studio C18/MPLINK build rules >>>HERE<<<
Sweet!
I haven't had a chance to test it, but I will.
Eric Haskins KC9JVH
Unread 19-01-2008, 15:36
TheGouger's Avatar
TheGouger TheGouger is offline
FRC #1053
TheGouger is an unknown quantity at this point
Good job. I have VS 2008 and it compiles with no problems. I haven't had the chance to test it on our robot, but I'll be able to do that sometime next week (I doubt there will be any significant problems )
Unread 25-01-2008, 01:22
FRC #2002 (TETRA)
Here's an updated toolchain, which now includes a C# program which regexes the C18 output in order to make the error list work. Yay!
NEW TOOLCHAIN WITH ERROR FORMATTER
Note that this doesn't work with linker errors or warning level 3 messages (default is level 2).
Source is included; pls. upload if you improve it.
Unread 03-03-2008, 07:48
Heffo Heffo is offline
Heffo is an unknown quantity at this point
Hello,
Thanks for posting the information on how to use C18 from inside Visual Studio. I really hate the interface in MPLAB and love Visual Studio.
I have my *.c files compiling properly, generating the object files, but for some reason, the linker isn't being started to build the hex file. Do you have any suggestions as to what may be the issue.
I am using Visual Studio 2005 Professional.
Regards,
Robert Heffernan
Build problems: MPLink 4.15 Linker... help? Trav-O Programming 2 12-01-2008 14:26
Confused on some rules about hurtling here Ghandric Rules/Strategy 2 10-01-2008 12:37
Visual Studio 2005 SP1 EHaskins Programming 0 21-12-2006 11:36
MPLink Error cloudago Programming 2 01-02-2005 23:00
Any pratical use for Microsoft Visual Studio .NET Pro Kyle Fenton General Forum 11 28-01-2003 16:59
