Go to Post [I] [/I]I think this may be some kind of record. We got through 9 entire posts before someone mangled the spelling of mecanum. [I] [/I] - Ether [more]
Unread 25-01-2008, 06:37
ChrisR_522's Avatar
ChrisR_522 ChrisR_522 is offline
FRC #0522 (Robo Wizards)
ChrisR_522 is an unknown quantity at this point
Send a message via AIM to ChrisR_522 Send a message via MSN to ChrisR_522
Limit Switches
How can we go about thoroughly programming the limit switches to control a specific motor using MPLab,
ex: if ((dig_in03)) { pwm03 = p3_y; } else { pwm03 = 127; }
Is that the correct way?
Any help would be greatly appreciated, Thanks!
http://robowizards.com/
http://img.photobucket.com/albums/v83/DAL_762/robowizards522animation.gif?t=1168394300
Unread 25-01-2008, 07:10
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
Re: Limit Switches
You're up a bit late, aren't cha? (Or early? Do programmers ever get to see the sun?)
I think it's rc_dig_in03.
Here's some code we had from last year, using joystick 2 y-axis to move the grabber arm up or down (like your lower arm with the motor at the elbow). We had a limit switch (LS) at the top and bottom to stop the motor, but allows it to go the other way even if it reaches the limit switch.
   //-------------------------- ARM WORK 3 -------------------------------------
   //Arm desired direction is from JoyStick2, Y-axis. UP goes fwd, DOWN is back.
   //pwm05 is the motor. LimitSwitch 5 and 7 is fwd and back stop points.
   //Change pwm numbers of motor, LS, and Joystick as need be.
   if (p2_y >(127+50))                          //If Joystk2 Y pushed up - arm forward
      if (rc_dig_in05 == 0)                     //is LS5 not pressed?
         { pwm05= 127+3; }                     //  No- turn motor on!
      else
         { pwm05= 127; }                        // Yes- turn motor off!
   else if (p2_y < (127-50))                    //If Joystk2 Y pulled back - arm backwrd
      if (rc_dig_in07 == 0)                     //is LS7 not pressed?
         { pwm05= 127-3; }                     //  No- turn motor on!
      else
   else
      { pwm05= 127; }                           //Turn motor off
Of course if you're doing autonomous, don't use the joystick! Just remember to cover all possibilities (all if/ifelse/else's) so you know at the end the motors are on or off.
This wasn't our final code, but it did work at the time. As always YMMV.
______________________
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Unread 25-01-2008, 08:04
ChrisR_522's Avatar
Re: Limit Switches
Hey, thank you so much! It worked!
Alternative to limit switches? RbtGal1351 Electrical 27 10-12-2005 15:30
limit switches stephenthe1 Programming 28 11-05-2005 16:37
Limit Switches help. Xufer Programming 9 21-04-2004 21:21
Limit switches Team168 Programming 8 10-02-2003 16:22
Limit Switches/Pots Brett W Technical Discussion 3 28-01-2003 14:25
