Go to Post Remember that starting a team is ALOT of work, but it’s a lot of fun once it gets going. Its all about the students, so don’t get too carried away ;) - Travis Covington [more]
Unread 25-01-2008, 08:41
Mike.Allen Mike.Allen is offline
FRC #2092
Mike.Allen is an unknown quantity at this point
How do you...
How and where do you mount the following sensors on the robot?
Differential Peak-Detecting Gear Tooth Sensor
Allegro Microsystems PN ATS642LSH
Dual-Axis Accelerometer
Analog Devices PN ADXL204
Yaw Rate Gyro
Analog Devices PN AD22304
Unread 25-01-2008, 08:46
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: How do you...
The gear tooth sensors mount inside the kit transmissions.
The other two can be mounted wherever you find a convenient place, and should be protected from damage somehow, perhaps placed on the electronics mounting area, with a cover over the whole thing (Lexan polycarbonate sheet can be used to make a good strong clear cover)
Unread 25-01-2008, 09:35
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: How do you...
As said above, the GTS mounts in the transmission boxes - you can see two mounting holes in the clear lexan for them.
The Gyro should be placed at your center of gravity - if you place it else where, the numbers will drift pretty badly as you move around the field.
The accelerometer can be placed anywhere in the robot.
All of them need to be protected from other robots and all moving parts - they are a little delicate. Last year the KoP had a different transmission with no mounting holes for the GTS, so we had to make our own mount. The gear one of them was sensing slipped on its axel and ended up grinding the GTS and ruining it, so keep safety in mind when locating these things!
Unread 25-01-2008, 11:37
FRC #2092
Re: How do you...
Thank you very much!
Mike and Team.
How do you feel about how the Autodesk award winners were decided? R Stephenson Inventor 43 02-06-2007 20:45
How old were you when you got your first real job? Ashley Christine Chit-Chat 31 24-08-2005 13:58
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
How many extra batteries should you bring, and where can you buy more? haverfordfords Electrical 6 08-02-2005 22:01
How did you learn how to use Inventor? Greg McCoy Inventor 26 24-05-2003 01:55
