Re: How would you machine this?
If you have access to a horizontal mill with a long enough table, you could just bolt the piece directly to the table and use a 3/4in cutter. You'd have it done in one pass and it'd be almost dead on. Just make sure the piece is square to cutter.
Now, if you have the sides accurate enough, you could do it in two or maybe three passes. Pass one: one end to about the middle. Make sure the vise or other holder is straight first, though. Pass two: Move the table back to start. Move the part to the middle, using the quill to help align. Repeat first pass. Do not have the tool contact the metal when you start! Pass three: Repeat pass two. |
How about a metal blade on a table saw? To get the 3/4" slot you may need to rip it twice, but it should be fairly accurate. You can always plug the extrusion with some wood after the first cut to keep it straight and true. Metal blades aren't cheap, but neither are 5' travel horizontal mills...
Bengineer |
Is this to lighten the part, or is it a track for something to move in?
A manual mill may do it like eric said if you can keep the vice straight. I also like Ben's idea of a table saw. |
Thanks for all of the quick replies! Last edited by Tapoore : 25-01-2008 at 14:46. |
Laxphan,
We regularly cut 1/8", 1/4", and 1/2" thick aluminum on our table saw here at work. It is, obviously, a little more heavy duty than your run-of-the-mill consumer table saw. But with the proper tooling and use, a table saw can certainly cut aluminum material. I'm not saying that I'm the one doing the cutting, as I know that I am not experienced enough to work with the thicker materials. But, it can be done, and could actually provide the precision that is asked for in this application. Bengineer |
#8
The shape you are looking for could presumably be formed from 3 pieces. A C-channel and two pieces of L angle. Rivited, welded, whatever.
#9
As for my personal solution to machining this object you two option if you have access to mill you can mill the slot in two passes with 3/4" 2 flute mill bit by flipping the piece around. You should have no trouble doing this on any stage 1 or 2 bridgeports 9" x 41" tables. However if you dont have a nice mill. you have another option. We have a dewalt router about 4hp that we can put mill bits in for doing similar processes. If you go this route you need to create a jig to clamp the work piece and also a guide for the router to follow so it stays on the same cutting path. The mill is a far better option but we have used the router before and it works great much better than a table saw ever would. However you need the correct machine for any process therefore a 3/4 hp router is made for cutting wood not cutting metal. |
| So how would you fix this year's game? | AnonymousMan | General Forum | 6 | 09-01-2005 09:36 |
| How much would you pay - Championship? | Steve W | General Forum | 2 | 03-06-2004 19:20 |
| How much would you pay - Regionals? | Steve W | General Forum | 10 | 03-06-2004 19:18 |
| Would you like to learn how to sign? | OneAngryDaisy | General Forum | 0 | 05-03-2003 20:11 |
| Buckeye Regional: How would you judge? | Wayne Doenges | Regional Competitions | 6 | 21-03-2002 21:33 |
