Go to Post One of the big things in FIRST is going global. - JosephC [more]
Unread 25-01-2008, 11:42
jax1488's Avatar
jax1488 jax1488 is offline
The Northern Chicken Wizards
AKA: jack stone
FRC #0522 (Robo Wizards)
jax1488 is a name known to alljax1488 is a name known to alljax1488 is a name known to alljax1488 is a name known to alljax1488 is a name known to alljax1488 is a name known to all
Send a message via AIM to jax1488 Send a message via MSN to jax1488 Send a message via Yahoo to jax1488
MAKE A MOTOR PULSE????
Hello, I would greatly appreciate if someone could help me figure out how to make a motor pulse using MPLab. For example, The motor (pwm03) needs to pulse on and off continually every second. Any help programming this would be greatly appreciated!!
"i dont like it, but i cant tell u why!" -"Dearrin"
2006 "aim high" national championship champions. (ty 296 and 217, NOTHERN CHICKEN WIZARDS... UNITE!)
2006 Greater Toronto Regional Chairman's Award
2004 N.Y.C. Regional Champion
2004 N.Y.C. GM Industrial Design
2004 N.Y.C. Daimler Chrysler Team Spirit
2003 N.Y.C. Regional Champion
Unread 25-01-2008, 11:55
rhoads2234's Avatar
rhoads2234 rhoads2234 is offline
AKA: Erin
FRC #2234
rhoads2234 will become famous soon enough
Re: MAKE A MOTOR PULSE????
why do you need it to?
use a timer and check it and then do mod math to find the time and turn on or off according to it
ALWAYS a mechanical problem!
Unread 25-01-2008, 12:03
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
The easy way to do this is:
You know that user_routines.c Default executes once every 26 (approx) ms.
That means that every 38 loops is nearly exactly 1 second. Simply write a counter, and then an if-then-else. It would look something like this:
count=count+1;
if (count == 38)
pwmXX=255;
count=0;
else
pwmXX=127;
Note you would want to declare the counter as a static variable.
Unread 25-01-2008, 12:50
jax1488's Avatar
AKA: jack stone
i need a little more help with this. Where exactly would i put the variables unsigned char unsigned int? Or does anyone have a simpler way of doing this? Please let me know i really need help. Thank You.
Unread 25-01-2008, 13:44
Tom Line's Avatar
The only variable involved is your counter. Put it in the declaration section of the routine that you put the code in. This is generally located at the beginning of the routine before any of the code, but after the open bracket {
Unread 25-01-2008, 14:14
jax1488's Avatar
AKA: jack stone
eh, unfortunately, i'm still kind of lost. Someone please help
Unread 25-01-2008, 14:37
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Ok, can you tell us how much experience you have with programming first of all.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 25-01-2008, 14:40
jax1488's Avatar
AKA: jack stone
well i can program the robot to move , program relays, sometimes digital inputs.... switches, triggers, buttons, autonomous.
Make my motor turn! [RSMT]sturm Programming 6 24-01-2008 07:54
make motor go slower coolguybigt Motors 1 19-02-2007 09:36
Remote Pulse Monitoring System kaveena Programming 1 19-07-2006 10:02
Measuring a Pulse Width MikeDubreuil Programming 22 21-07-2005 10:22
PUlse counting junkyarddawg Technical Discussion 1 31-01-2002 15:33
