Go to Post By inviting engineers and mentors to be a part of your team and partnering with them...brings added value, depth, strength, expertise, and wisdom to the team and to the overall experience. - JaneYoung [more]
Unread 25-01-2008, 14:16
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
MPLAB syntax error?? No Way!!
OK, I am no programming Guru, so I am asking for help.
I am coding a simple torque limiting function. I have very carefully checked my work, yet when I "Build All", MPLAB says I made a Syntax error. When I comment out the entire function, the error goes away. Please take a look at it and comment to your hearts content. The error is on line 111, which is where my first "if" takes place.
*	Function name: Torque_Limit
*	Purpose: Reduce max torque to allow smoother driving transitions
*	Called from: autonomous./Autonomous(), and teleop.c/Teleop()
*	Arguments:	Target value from code or joystick, Previous value of pwm,
*   Max change (MAXTORQUE). DO NOT FORGET TO STORE FINAL PWM VALUE TO CORRECT
*   VARIABLE (lastpwmXX) WHEN RETURNED!!!
*	Returns:	(int) pwm value
int Torque_Limit (int target, int previous)
	int setpmw;
	if((target - previous) > MAXTORQUE)
		setpwm = (previous + MAXTORQUE);
	else if((previous - target) > MAXTORQUE)
		setpwm = (previous - MAXTORQUE);
	else
		setpwm = target;
	return setpwm;
See the screen shot for the error.
Unread 25-01-2008, 14:23
Re: MPLAB syntax error?? No Way!!
what is MAXTORQUE defined to?
Unread 25-01-2008, 14:24
mgurgol mgurgol is offline
FRC #1094
mgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nice
you are defining setpmw, but using setpwm after the if statements
Unread 25-01-2008, 14:26
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Yep.
Is that a valid return statement? I thought it should be return(variable);
Unread 25-01-2008, 14:27
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
Silly question, but MAXTORQUE is defined globally somewhere? Hmm... is that a syntax error or something else?
If you comment out the first if thru to the else /*if .... else*/ so the else if is now an if, does the error drop down to that if or does it go away?
Unread 25-01-2008, 14:33
FRC #1153
Rookie Year: 1900
The setpwm / setpmw error will crop up after this error is fixed.
Heh. I feel like I'm on a game show, with all these answers coming back.
billbo911's Avatar
Currently MAXTORQUE is defined to a value of 100 in the bob.h file. It will be modified once we experiment a little.
Originally Posted by mgurgol View Post
you are defining setpmw, but using septum after the if statements
OK, I corrected my spelling error (thank you), but am still getting the same error for the same line of code.
Unread 25-01-2008, 14:37
Is there an include statement for bob.h in this file?
Did you put a semicolon or anything after #define MAXTORQUE 100
Unread 25-01-2008, 14:38
FRC #1153
Rookie Year: 1900
Does this c file #include the bob.h file? Or is this file bob.c? If you (temporarily) define MAXTORQUE in this file does the error go away?
Unread 25-01-2008, 14:39
billbo911's Avatar
Yep, MAXTORQUE is defined in bob.h.
I tried the comment out as you suggested before posting the question. The error moves to the new "if" statement.
Unread 25-01-2008, 14:48
FRC #1153
Rookie Year: 1900
I tried the comment out ... The error moves to the new "if" statement.
That shows that both those if statements have the same error. Probably not an imbalanced { } from above. (You can remove the /* comment */). I'm still thinking the #define MAXTORQUE isn't being seen by this file.
If you change MAXTORQUE to 100 does the error go away?
(I'm also imagining poor billbo911 running from the computer with mplab all the way across the room to the computer with internet access.)
Unread 25-01-2008, 14:49
billbo911's Avatar
Yes, bob.h included.
No, it doesn't go away when defined locally.
Yes, bob.h is included.
No semi-colon on definition. BUT!!!
We have a winner!!! The line looked like this "#define MAXTORQUE = 100" The equal sign killed it.
Originally Posted by Tom Line View Post
Yep.
Not the problem. Tried both ways. Problem solved above!
THANK YOU EVERYONE for helping me find this problem.!!
Note to self: "=" good in variable declaration, bad in definition.
Unread 25-01-2008, 14:51
billbo911's Avatar
Luckily, I have access on 2 side by side computers. It makes this much easier!
180:Error: syntax error help! seanl Programming 8 04-02-2007 11:31
MPLAB syntax problem dpick1055 Programming 6 23-01-2007 13:28
C18 v2.4 -- Syntax error where there is no syntax error Joel J Programming 7 12-01-2007 17:27
Syntax Error! Denz Programming 15 04-02-2006 23:57
