Go to Post It will really be different for us (ESPECIALLY since our robot drives consistently this year). - Karibou [more]
Unread 25-01-2008, 10:40
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
pulling gear on Keyang motor??
Anybody know if the spur gear on the Keyang motor can be pulled so we can put something else on the shaft?
Bruce
Unread 25-01-2008, 10:50
Tapoore's Avatar
Tapoore Tapoore is offline
AKA: Tom Poore
FRC #1519 (Mechanical Mayhem)
Tapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of light
Re: pulling gear on Keyang motor??
I believe the Keyang gearbox is considered an integral part of the motor and can't be modified. The actual rule is in <R61>.
- www.mechanicalmayhem.org -
* 2015 Granite State District Event Champions
* 2013 Einstein Finalists
* 2006, 2010, 2011 Granite State Regional Champions, 2009 Chairman's Award
* 2012, 2013 North Carolina Champions
Unread 25-01-2008, 11:14
Bruceb's Avatar
Here is the rule you mentioned.
<R61> So that the maximum power level of every ROBOT is the same, motors used on the
ROBOT shall not be modified in any way, except as follows:
 The mounting brackets and/or output shaft/interface of the motors may be modified to
facilitate the physical connection of the motor to the ROBOT and actuated part.
 The gearboxes for the Fisher-Price and Globe motors are not considered “integral” and may
be separated from the motors.
 The electrical input leads on the motors may be trimmed to length as necessary.
The intent is to allow teams to modify mounting tabs and the like, not to gain a weight reduction
by potentially compromising the structural integrity of any motor. The integral mechanical and
electrical system of the motor is not to be modified. Note that FIRST will not provide
replacements for modified parts.
I think it is stating that we can modify the output shaft.
Am I reading it wrong?
Bruce
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Is the spur gear actually part of the gearbox though?
EDIT: R61 says it is not. So you should be fine. Looking forward to seeing you at the Wisconsin Regional.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 25-01-2008, 11:26
Tapoore's Avatar
AKA: Tom Poore
Now that I think about it, I remember that there is something unusual about the way that the spur gear is attached to the motor shaft on the Keyang. There is actually another spur gear inside the gearbox that's inserted inside the wormgear. If you remove the stock spur gear, you will probably need to machine a custom insert to fit in the worm gear, so I'm not sure that removing the stock gear would help you. You should probably take a look at the Keyang for yourself so you know what I'm talking about (because it sounds confusing to me).
Unread 25-01-2008, 11:30
AndyB's Avatar
AKA: Andy Burchardt
I think you are confused.
The spur gear he is referring to is on the outside of the gearbox, on the output shaft. It couples with one of the half dozen black hubs you received in the kit of parts.
Unread 25-01-2008, 11:57
Tapoore's Avatar
AKA: Tom Poore
The outside spur gear has a smaller spur gear attached to it that couples directly with the worm gear on the inside. This isn't at all obvious from just looking at it. I took one of these apart last year and was surprised to see how it was attached.
Unread 25-01-2008, 12:12
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
That makes sense to me....it's the easiest way to attach the inner gear to the outer one-- the outer gear is long enough to fit into a gear shaped hole in the large diameter inner gear.
So the shaft itself is not really what is transferring torque.
Unread 25-01-2008, 12:17
Tapoore's Avatar
AKA: Tom Poore
You got it exactly.
Unread 25-01-2008, 12:32
Bruceb's Avatar
Hmm, was hoping not to have to use the plastic coupler. Wanted to put a timming pulley on the shaft instead of the gear.
Bruce
Unread 25-01-2008, 13:05
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Bruce
You could always try using a pulley large enough to machine a coupler out of the center. It's not the easiest thing to do, but you could make a hole the same size and shape as the output gear, and just press the pulley on to the gear.
Jeff Waegelin
Unread 25-01-2008, 14:24
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Were you able to take it apart without damaging the gearbox? We stripped the plastic spur gear on the inside last year after wear and tear from 2 competitions and a lot of demos, and I was trying to take it apart and confirm it actually was stripped. I didn't want to completely destroy the motor/gearbox assembly though, and it looked like you had to dremel off the metal tabs to get it open. Is this correct or did you do it a different way?
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 25-01-2008, 14:51
Tapoore's Avatar
AKA: Tom Poore
I think that I just had to remove the retaining clip on the end of the shaft.
Unread 25-01-2008, 15:03
artdutra04's Avatar
VEX Robotics Engineer
This works really well; last year 228 machined a custom aluminum coupler for the window motor (as seen in the photo below). It took a long time to machine it manually, but I wouldn't hesitate doing it with access to CNC milling (which I have here at WPI ).
Art Dutra IV
世上无难事,只怕有心人.
Unread 25-01-2008, 15:06
Engineering Mentor
Wow, how in the world would you do that manually? Even with a digital readout and a nice mill, don't you need a CNC machine to move in x and y directions at the same time? I guess if you had a rotary table, that would help a lot, but would you still be able to get everything to the correct dimension?
Keyang Motor Spur Gear Pitch Dan Petrovic Technical Discussion 4 24-01-2012 21:35
Keyang Motor Gear Profile LieAfterLie Motors 6 23-02-2007 17:16
2 motor adapter and keyang motor dimensions Bruno Estevão General Forum 1 16-02-2007 09:36
keyang motor wedellm Motors 2 14-02-2007 02:37
Keyang Window Motor Gear pitch AdamHeard Technical Discussion 3 19-01-2007 12:12
