Go to Post Deodorant cannot be stressed enough. To quote a teammate "body odor is a body don't-or." - C. De Vries [more]
Unread 22-01-2008, 08:13
roborat roborat is offline
roborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to behold
Re: Problem with 2008 gear tooth sensor
My second sensor also seems to be bad with a reading of 3.69 on the signal wire. Guess that we will order a new honeywell sensor this morning.
Unread 23-01-2008, 19:53
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
One of ours sits at 3.6 volts too! We are hooked up the other one before putting the other gearbox together. It works. So one good, one bad here too.
Brian K
Team 1225 Robotics Mentor
Unread 23-01-2008, 20:24
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
I'm with most of you saying that one of the GTSs is bad. We wired ours up yesterday, one worked, the other did not. We got one of the ones from last year, and it worked, so we're sticking with that. I guess that would be legal since in the KOP they included two, and we are only using two. The one from last year is identical to this years except the fact that the colors changed.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 23-01-2008, 23:16
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We have one good sensor, one bad one too. The bad one is the one at the outer end of the "full" board...that is, it only has one edge cut. Maybe there's a manufacturing or design problem with the circuit board itself? or a part on wrong? that could be fixed?
Also has anyone asked on Q&A if they'll make an exception and allow using previous year KOP sensors because of the apparent systemic problem with the new boards?
Unread 24-01-2008, 20:21
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Hey everyone! i think our team found the source of the problem.
check out R3 on the two boards. the number on them is different.
Apparently, R3 on the end gear sensor board is marked 4001, R3 on the other gear sensor board is marked 4004. Our mentor assumed that one is 400 and 40k Ohms, but he was not sure how to read the surface mount resistor markings. It is clear they made a mistake in the factory and built all of one of the two boards incorrectly.
Hopefully, more information will be posted later today about this problem.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 24-01-2008, 23:07
MrForbes's Avatar
AKA: Jim
We found that R4 is different, I did not look at R3 yet.
let's see how this picture came out? oh, I have to split it up....
ID:	6128  Click image for larger version
Unread 24-01-2008, 23:12
The Blue Alliance
OH! R3 AND R4 ARE SWITCHED!
Eugene Fang
Unread 25-01-2008, 13:45
Tim Skloss's Avatar
Tim Skloss Tim Skloss is offline
Dr. Skloss
FRC #0930
Team Role: Parent
Tim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the rough
It would be legal only if the sensors from last year are freely available to ALL teams as a commercially available part. So if you can prove that they can be purchased today by any team, then you are OK.
FIRST Mentor and Team Leader
C.O.R.E 2062 a NASA, GE Volunteers and Rockwell Automation FRC Team
Unread 25-01-2008, 15:11
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Markings per http://www.vishay.com/docs/20020/smdmark.pdf
4001 - 4k ohm
4004 - 4 meg ohm
Unread 25-01-2008, 18:20
Tim Skloss's Avatar
Dr. Skloss
FRC #0930
Team Role: Parent
It would be great for someone to swap the resistors so they match the working GTS board and verify that it fixes the problem.
All of us want to know if there is an easy way to fix the bad board!!!
Unread 25-01-2008, 20:47
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
I can verify that swapping the resistors fixes the board. Don't attempt it without the right equipment, though.
Unread 16-02-2008, 20:40
baop858 baop858 is offline
FRC #0069 (Hyper)
baop858 will become famous soon enough
Send a message via AIM to baop858
Which one is the working one?
Unread 18-02-2008, 11:39
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
The bad one is the end board on the sensor strip. The good one is the next one in. If you have already separated your boards (and I'm thinking that by now you should have) the board with one smooth edge is the bad one and the one with 2 small nibs on opposite edges is the good one.
2017 Season; Game Announcer at
SBPLI Long Island Regional
Gear Tooth Sensor marco_alchemy Electrical 7 06-02-2008 09:54
Help with Gear Tooth Sensor RedOctober Electrical 3 27-01-2006 18:38
Gear Tooth Sensor Talha Electrical 1 23-01-2006 21:29
gear tooth sensor connecting problem nirty Electrical 2 23-01-2006 12:17
Gear Tooth Sensor AMIRAM Electrical 2 22-01-2006 04:09
