Go to Post It does it automagically. - David Kelly [more]
Unread 25-01-2008, 16:54
libertyrobotics's Avatar
libertyrobotics libertyrobotics is offline
FRC #1764 (Liberty Robotics: The Dirty Gears)
libertyrobotics is an unknown quantity at this point
Exclamation Re: pic: FRC488 Completed Drive Train
here is a teaser of just our frame!!!!!!!
Unread 25-01-2008, 17:04
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
Re: 1764 Frame Teaser
Cool design for an Omni drive. Have you done any programming for it yet?
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 25-01-2008, 17:05
Jaybee1405
Posts: n/a
hollistic drive looks great!
Unread 25-01-2008, 17:06
GaryVoshol's Avatar
Cogito ergo arbitro
Looks good. Check your bumpers - there was a post in Q&A just yesterday I believe that prohibits mitered pool noodles into the corners, even if the wood doesn't extend into the corners.
(since 2004)
Yes there is programming for the prototype that is setup the same. And can you tell us where you found that information for the bumper?
Unread 25-01-2008, 17:07
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
very cool, I am assuming the electronics are mounted above this piece?? if not thats a pretty tight squeeze lol!
looks sweet though!!
Unread 25-01-2008, 17:10
AKA: Joey
Can you get it to go in all directions? If you need help, let me know. I worked with an omni drive vex robot over the summer.
Joey
Unread 25-01-2008, 17:11
there will be a plate on the underneath the frame (beneath the motors) and on the battery plate
Unread 25-01-2008, 17:12
we don't need help with programming but thank you and yes it does go in every direction.
Unread 25-01-2008, 17:15
You mean this one, I believe.
Unread 25-01-2008, 17:57
If you're interested....see video below.
In the video our robot is only doing a third of what it's capable of. The first half is on ceramic tile and then the second half shows the capabilities on carpet. Our programmer estimates the top speed to reach 15ft/s.
Direct link to video:
http://www.liberty.k12.mo.us/hs/libe...ive%20test.wmv
Our website:
http://www.liberty.k12.mo.us/hs/libertyrobotics/
Unread 25-01-2008, 18:02
AKA: Joey
Our website:
The video on your page doesnt work. Might want to have someone look into that.
Joey
Unread 25-01-2008, 18:05
click on our website link and then go to 2008 competition and watch the video from there. If it doesn't come up you have to run activex control to see (we have to here).
Unread 25-01-2008, 18:07
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Actually the direct link was just entered improperly. If you do want to directly download and view the file, try this one:
http://www.liberty.k12.mo.us/hs/libe...Drive test.wmv
Otherwise you can go their website as described above to view it embedded in the page.
Unread 25-01-2008, 18:09
thank you for doing that!
pic: Frame is falconmaster Extra Discussion 1 17-01-2008 23:11
Steel Frame? gburlison Technical Discussion 20 18-12-2007 16:56
the frame kaboose Technical Discussion 7 11-01-2007 22:38
Frame Dragging Wetzel Math and Science 0 22-10-2004 17:10
pic: 111 Teaser (tiny teaser) CD47-Bot Robot Showcase 15 04-03-2003 00:49
