Go to Post Chit Chat is frivilous but CD would be a colder place without it. - Koko Ed [more]
Unread 25-01-2008, 17:12
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
pic: Virginia's DREAM top view
Unread 25-01-2008, 17:13
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
Re: pic: Virginia's DREAM top view
Is the position of your radio legal? One of our team members thought the radio must be mounted verticly. Was he wrong?
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 25-01-2008, 17:31
in between teams
AKA: Luke Van Oort
It can be mounted however you want, but it should be mounted vertically for optimal reception. The antenna on the outside of the radio isn't the only one, there is one on the inside too, so just sticking the external antenna up isn't as effective a mounting the whole thing vertically. We mounted our radio horizontally last year and it was identified by IFI as a radio that might have some "issues" that the software upgrade didn't fix, but we had no issues. I would recommend mounting it vertically though; we mounted our like we did because we didn't have many options--our only options were to mount it horizontally, on our turret, very close to our drive chain, or right next to our main power distribution.
Instead of trusting a team member's information (which can be wrong) or info from post on CD (which can also be wrong, but someone usually corrects incorrect answers), you should read the manual yourself. Reading the relevant sections only takes about an hour to a couple of hours; the amount of time it takes depends on reading speed and what sections are relevant--a build team person probably doesn't need to read the criteria for the website award, for example (although it is probably a good idea to do so anyway). Even if it takes 4hrs, it will be the most useful 4hrs you spend all build season.
Team 1219: 2009 - Mentor
Unread 25-01-2008, 17:53
AKA: Joey
Thanks for the help. I read the manual, and so did the team member who thought it needs to be mounted verticly. The problem is the manual contains so much info, that it is hard to remember all of it. We were going to look through the manual for it, but I saw the picture of it mounted sideways, so I thought I would ask.
Joey
Unread 25-01-2008, 18:20
N7UJJ N7UJJ is offline
Teacher
AKA: Allan Cameron
FRC #5465 (BinaryBots)
N7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond repute
The photo of "Virginia's DREAM" is just the drive train module. We are still building a "ball lifter" which will be mounted on the drive train and the radio transceiver will eventually be mounted on the superstructure. The radio placement you see in the photo is temporary. Currently we are running the robot around the halls so prospective drivers can get some practice.
One advantage of our builinding material, extruded fiberglass, is that it is transparent to radio waves so the fiberglass does not block the signals.
Having the external metal antenna and the internal antenna "vertically polarized" does make a difference, assuming that the operator radio antennas are also vertically polarized.
Unread 25-01-2008, 18:41
Synergy1848's Avatar
Synergy1848 Synergy1848 is offline
Vex Career: 84-20-1
AKA: Tony
FRC #1848 (SOUP)
Synergy1848 will become famous soon enoughSynergy1848 will become famous soon enough
just curious, why is the front angled in?
FRC# 1848 Team Soup
2007 Peachtree Winner 2008 Peachtree Imagery Award Winner
Mr. Roboto and Super Pals
2005 FVC 24 finalist, 2007 FVC 2024 NC winner, Champs 3rd seed; semi-finalist
2008 FTC 3 Tn Winner, Inspire award, Motivate award Ga Finalist, Amaze award Champs '08 Franklin
Unread 25-01-2008, 18:47
Teacher
AKA: Allan Cameron
Squeeze through traffic bottlenecks
Unread 25-01-2008, 18:49
Vex Career: 84-20-1
AKA: Tony
FRC #1848 (SOUP)
i figured it had something to do with the racing portion of the game
FRC# 1848 Team Soup
pic: Top view Cheesed robot falconmaster Extra Discussion 4 18-01-2008 12:03
pic: A View From the Top CMB Extra Discussion 2 10-01-2007 22:21
pic: Lego Kiwi Bot Top View Michael Corsetto Extra Discussion 2 02-01-2007 10:46
pic: Top View of Shaft Drive MAteo9944 Extra Discussion 2 30-12-2006 20:59
pic: Team #910 Top View CD47-Bot Extra Discussion 7 06-03-2003 12:41
