QUESTION ABOUT THE MOTOR
My team had a problem with getting the motor to run backward so we switched the positive and negative wires. does anyone happen to know if that is allowed or if it will pass inspection?
Thanks-Team1763 Last edited by Bre92 : 25-01-2008 at 17:58. |
Re: QUESTION ABOUT THE MOTOR
This is perfectly acceptable. The inputs to the Victors have a set polarity. You can switch the wires on the output to get the direction right.
Yes. Wires with a non-constant polarity do not have to be color coded, <R54>
This is expected and perfectly legal. Inspectors will only look at the wire size and colors. At the output of Victors and Spikes there is no set rule for color as pointed out above. Hook up the outputs only to satisfy your design and motor direction. The only exception is the compressor if you choose to use one. When connecting this to a Spike, follow the color code on the motor wiring (red to M+, Black to M-). The compressor runs in both directions but is much more efficient (less heat) running the correct way. |
| Question about the IR sensor | DemonYawgmoth | Electrical | 4 | 08-01-2008 22:26 |
| Question about Fisher Price Motor Connectivity: | Joobacca | Motors | 1 | 05-02-2007 13:24 |
| Question about 3rd Tutorial ETA and FRC Modeler Motor Config | Ted155 | LabView and Data Acquisition | 2 | 21-01-2007 19:45 |
| question about atwood motor | matt sorgenfrei | General Forum | 1 | 19-01-2002 08:31 |
| question about atwood motor | matt sorgenfrei | Motors | 0 | 18-01-2002 23:19 |
