Re: Shuper Shifter servos hookup and programming
Servos connect directly to a PWM output on the Robot Controller.
Control their position the same way you would control motor speed using a Victor. Setting the PWM output to 0 will drive the servo output to one limit of travel, setting it to 254 will drive it to the other limit, and setting it to 127 will move the servo output to the center of its travel. You'll probably want to experiment to find the proper numbers to put the actuator in the right spots for high and low gear, because the servo can overheat if it's constantly trying to push against a physical limit. |
| Rack and Pinion/Motors and servos | psniffler | Motors | 7 | 25-01-2008 16:16 |
| Programming Servos For AndyMark Transmission | de_ | Programming | 6 | 30-01-2007 08:52 |
| servos and the camera | incognito_NICK | Programming | 5 | 09-02-2005 00:00 |
| Encoder Hookup | kutty18 | Electrical | 4 | 22-01-2005 12:17 |
| Line Sensor hookup | Dinush | Electrical | 9 | 15-02-2004 23:13 |
