Go to Post Successful teams - in almost any aspect of life (i.e. not just robotics) - don't make excuses and assign blame when something goes wrong. They improvise. They adapt. They overcome. They correct the problem and move on. - dlavery [more]
Unread 25-01-2008, 20:41
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
Wiring of Papst Fans
Our team is worried about heat buildup in certain areas of our robot. Our plan is to have the 4 CIM motors to drive the robot, and the Victor 884 speed controllers for these motors will be all lined up next to the motors. I know that the Victors generate a significant amount of heat, and we have had problems with motors over-heating. The problem is further exacerbated by the fact that we're effectively putting a "lid" on the whole system, by mounting the rest of the electronics directly above this. So, my first question is:
1) Should we be worried about heat?
And
2) If so, what should we do about it?
One possibility we are looking at is wiring up two of the larger fans to give this "hot-spot" more ventilation. However, I am confused about the wiring of the fans. I'm looking at the "Papst Multifan 4212 / 19H [...] 12V DC 475 mA [...] US-PAT: 5590235 5135363 RE34268". As far as I can tell, this is slightly different but functionally the same as the one that came in the kit this year ("Compact Fan (Large) [...] PN: 4112N/12GL-175"). The way this is wired suggests that it should be connected to a male 3-pin PWM-type cable on the Robot Controller (RC). Namely, it has the female end of the cable type on it. However, it does say "12V" and the RC supplies only 5V. In addition, I've tested it in Relay, PWM Output, Digital In/Out and Analog, and none of them make it spin.
Now, I would consider myself perfectly competent to clip the female connector and wire this thing up "by hand", so to speak, but the way it is wiring seems to suggest otherwise. I understand that many parts in the Kit are not designed for FIRST per se, but looking at the website (www.ebmpapst.us) suggested that the PWM-type wire is not the default connector. Specifically, it says in the PDF, "Electrical connection through AWG 22 leads. Stripped and tinned." So this is my third question:
3) How do I wire these gosh-darned fans? There's no good info on the site.
And just to sate my curiosity, if the answer IS "chop off the pwm connector and wire it", then
4) Why the flip is the PWM connector on there in the first place?
I think that's all for now. If someone could link me another thread that answers this I'd be grateful, but save the "search before you post" talk please.
Thanks in advance,
Paul Dennis
Team 1719
where to attach papst cpu fan? brennerator Technical Discussion 1 19-02-2007 09:06
Papst 4112 N/12GL fans X-Istence Electrical 2 04-06-2006 09:35
Large Papst Fan Sensor Team1726Nerds Electrical 4 16-01-2006 22:48
Using two Large PAPST Fans? SuperDave Electrical 9 17-02-2003 15:11
Sensor use on Papst Large Fan archiver 2001 6 23-06-2002 23:14
