Go to Post We all need to remember to be careful at these competitions. Danger lies in the most unexpected (and comical) places. - Alexander McGee [more]
Unread 25-01-2008, 18:28
AHepperla's Avatar
AHepperla AHepperla is offline
Oh yeah, you know it...
AKA: Wheels
FRC #2202 (B'East Robotics)
AHepperla is an unknown quantity at this point
Motor Speed
Hey guys, I was just wondering why, when we set the same PWM values to two different motors, why the motors are going two different speeds? Anyone know how to fix this through calibration or something???
Unread 25-01-2008, 18:43
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
Re: Motor Speed
It's because you've got one motor mounted backwards, and the motors actually have a preferential direction. If you have encoders on your drive shafts, we have some code we're working on right now that will make it drive straight.
I'm sure someone else will have some code up before I will, but if you send me an email to remind me I'll put it up by monday.
P.S. I'm literally working on it RIGHT now ... final touches ... (which means nothing, of course)
What place are we at? ... TODAI!
Unread 25-01-2008, 19:11
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: Motor Speed
also, manufacturing isn't perfect. we had this problem last year. what happens is 255 to one motor might only act like 230 (exaggeration) on another. one wyay to fix this is to individually slow down each motor to calibrate them:
pwmXX-=127;
pwmXX*=0.9 //for 90% power
pwmXX+=127;
the other (and preferred) way is to use sensors like (ideally) encoders, but you could use a gyro to make it go straight, or, dare i say it, gear tooth sensors as encoders (it only requires a slight modification to kevin's encoder code). the only problem is that GTS's have to be almost touching the gear to get a reading, and thereadings are usually pretty sketchy.
good luck!
Unread 25-01-2008, 20:02
AHepperla's Avatar
AKA: Wheels
Re: Motor Speed
Thanks for the help. Just wondering what kind of encoders you use/what kind do you recommend? Thanks again!
Unread 25-01-2008, 20:11
tseres's Avatar
Re: Motor Speed
as far as what kind of encoders, i'm not too sure. just do a search on these forums for encoders, and you'll find more than you need
Unread 25-01-2008, 21:31
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Motor Speed
Use any type of encoder, but use the same one for both wheels.
It should be this simple, though I haven't done it yet (that's for tomorrow if we have a rolling chassis).
right_encoder = Get_Encoder(1);
left_encoder = Get_Encoder(2);
difference = right_encoder - left_encoder;
if (p1_y < (p2_y + 15)) && (p1_y > (p2_y - 15)) //If they're within 15 of eachtoher
right_drive = p1_y - difference * constant; //adjust based on difference of encoders
left_drive = p2_y + difference * constant; //adjust based on difference of encoders
else
right_drive = p1_y;
left_drive = p2_y;
Adjust constant until you go straight. This is essentially a PID loop based on the encoder difference. This assumes a tank drive system, but the same concept is applicable to other drive systems.
Unread 25-01-2008, 21:39
The Lucas's Avatar
CaMOElot, it is a silly place
Re: Motor Speed
Calibrating the victors would not hurt. Instructions are here. Either calibrate both Victors or reset them both to Factory default (your choice).
Also, I use US Digital encoders. Other people have mentioned Banebots and Grayhill.
Robot Inspector
Controlling motor speed WGRAY Programming 9 16-02-2009 22:50
Motor speed HellBoy Programming 2 05-02-2007 10:41
Multi-Speed motor Questions Burg Robotics Education and Curriculum 2 23-12-2004 15:54
Drill Motor Speed Difference Mark Jones Motors 2 14-02-2003 15:23
Drill motor true speed? archiver 2001 0 23-06-2002 23:58
