Go to Post ...I pretty much got the impression that the balls are actually very small, cuddly landmines. - Gui Cavalcanti [more]
Unread 25-01-2008, 22:02
edgar_amaro edgar_amaro is offline
FRC #2582 (Pantherbots)
Team Role: Student
edgar_amaro is on a distinguished road
what do you think ???
ready to build our arm !!!
Unread 25-01-2008, 22:13
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: what do you think ???
Nice bumpers!
One thing that jumps out at me: you have very little engagement of your chain on your drive sprocket, which may cause it to skip teeth if you push against a wall. It's easily changeable with your setup, though, just add a couple of links to the chain and scoot the idler closer to the transmission.
Unread 25-01-2008, 22:26
Team Role: Student
well... the way it is right now ... the chain does not skip ... so yeah thanks fo the tip !!!
Unread 26-01-2008, 02:05
dtengineering's Avatar
AKA: Jason Brett
It looks like a good clean kitbot, with some great bumpers. I didn't check to see if you welded the frame, but if you run into weight issues welding not only adds stiffness but loses a pound or so of nuts and bolts. Some teams also use big rivets to hold the frame together.
Do lots of testing with the chain... forwards, backwards, forwards, backwards... into a wall slowly, into a wall quickly... preferably with some weights attached to approximate your final weight.
While various mechanisms can fail causing your robot to be less effective in a match than hoped for, when you lose a chain you become ineffective. Been there, done that, it is no fun at all.
I'm not saying that this set up won't work reliably, but if you lose a chain during the build period... even once... do not shrug it off as a fluke. Your robot is telling you something.
Jason
P.S. Have you tried pushing the ball against a wall yet? I'll bet it just jumps right up on top of your chassis, right where you want it.
P.P.S. If you have a couple Victor Speed Controllers left over (or if you order two more) you can order two extra CIM motors for $24 each and double your torque.... or change your sprockets and increase your speed.... unless you are already planning to use the extra CIMs elsewhere. If you do that, though... retest that chain set up at the higher torque settings.
Unread 26-01-2008, 05:40
AdamC's Avatar
AdamC AdamC is offline
Lathemeister
AKA: Batman
FRC #0395 (2Train Robotics)
AdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of light
Send a message via AIM to AdamC
I really like that! Looks like a solid, reliable base. Much like the others, I cannot stress enough the importance of testing your drive trains. We essentially lost all our regionals because of a lack of testing on all components of the robot. During nationals, we popped a chain on our right drive train and had to have an alliance robot bump up alongside us so we could drive to a good defensive position. Very embarrassing. I think just a little extra tension in your chains might make a big difference in reducing the risk factor.
"The glass is neither half-full or half-empty. It is twice as large as it needs to be."
"Any job worth doing is a job worth dying for."
Unread 26-01-2008, 08:33
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Indeed test test test and test some more. Once you think you have all of the bugs out test it until you find another.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 26-01-2008, 10:29
chinckley chinckley is offline
Winner 2009 West Michigan District
FRC #1254 (Entropy)
chinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to all
Question Re: what do you think ???
We really like it. I do have a question though that maybe you
can help us with. We see that you also have a low frame.
How did you hook your bumpers to the frame. We are worried that
we will have to add another level of frame to attach them too, but
now we see you seem to have yours attached to the lower frame.
How high off the ground is your frame?
How did you hook your bumper to it and still be in the 2.5 to 8.5 inch off the ground range?
We would appreciate any help.
Thanks,
Carolyn Hinckley
2009 West Michigan District Winner
Thanks to Team 216 and Team 1918
2009 Traverse City Semifinalist
Thanks to Team 1596 and Team 47
2009 Traverse City UL Safety Award Winners
Attending 2009: West Michigan, Traverse City, & State
Unread 26-01-2008, 10:55
Team Role: Student
ok ... well u know how the chassi has holes all throughout the middle.. right ??? .... what we did is .. we grabbed pieces of wood & drilled some holes on the bottom part... so that way the bottom of the chassi and the bottom of the piece of wood would be leveled at the same height... then we used some screws & bolts and attached them... to the chassi ..
ps.... our bumpers and chassi are 2.5 inches from the ground !!!
pss... ill try and look for a picture.. so that way you can see what im talkin about...
Unread 26-01-2008, 11:15
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
great start!!
A general rule of thumb is to have atleast 120 degrees of chain wrap around a sprocket. A drive sprocket should get 180.
1. Chain stretches
2. your robot will be pushing against other.
it will likely skip as the chain loosens and you push against other bots in competetions.
I would definitely recommend getting more wrap on that chain.
"we don't build robots, we build people"
Unread 26-01-2008, 13:07
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Looks good besides your wiring being wrong. Where is your distribution block!?
I like the bumbers.
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 26-01-2008, 16:07
Team Role: Student
hahaha............ well we have 2 levels for our elctrical system ... i dont know if you are able to see it
what do you think? Squeje250 General Forum 1 26-04-2005 21:42
What do you think? xxlshortys Fundraising 2 21-05-2003 21:15
So what do you think? Marygrace General Forum 12 06-05-2003 23:50
What do you think? archiver 2000 7 23-06-2002 23:28
So what do you think? archiver 2000 7 23-06-2002 22:19
