Go to Post There is nothing that says 'gracious professionalism' like making brunch for your opponents. - Monochron [more]
Unread 26-01-2008, 09:43
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
pic: 1726 Pre-Assembled Chassis
Unread 26-01-2008, 09:46
Tapoore's Avatar
Tapoore Tapoore is offline
AKA: Tom Poore
FRC #1519 (Mechanical Mayhem)
Tapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of light
Re: pic: 1726 Pre-Assembled Chassis
Amazing! How did you paint it?
- www.mechanicalmayhem.org -
* 2015 Granite State District Event Champions
* 2013 Einstein Finalists
* 2006, 2010, 2011 Granite State Regional Champions, 2009 Chairman's Award
* 2012, 2013 North Carolina Champions
Unread 26-01-2008, 09:47
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Krylon spray can from Ace Hardware. And some wet sanding between coats with 320 grit.
Unread 26-01-2008, 10:59
esisso esisso is offline
AKA: Eitan
FRC #1242 (Team Smiley)
esisso will become famous soon enough
Send a message via AIM to esisso Send a message via MSN to esisso
have you ever done your chassis with fiberglass before? is it structurally sound to hold the weight/ recieve the impact of collisions with balls, other robots, and the field?
i never thought about fiberglass seems like a new and cool idea
Unread 26-01-2008, 11:05
MrForbes's Avatar
AKA: Jim
This is our third year using it, we got the idea from our mentor team 842. The fiberglass we use is "pultruded" it comes in shapes like channel, angle, I beam, etc, and we use the 1/4" thickness.
It is amazingly tough, and it will not get bent like aluminum does. The density is lower than aluminum, so a 1/4" thick fiberglass part is just a little bit heavier than a 1/8" thick aluminum part of the same shape.
We've learned that having a heavy frame can be a good thing, it helps keep the robot from falling over--because it forces you to make the top of the robot lighter to meet the overall weight limit.
We have used fiberglass I beam for the main frame rails in the past, but this year with the mandatory bumper rule we decided that it would be ok to just use the channel, with the wheels outside of the frame rails. Estimated weight of the fiberglass parts pictured is just over 10 pounds (the channel is 4" x 2" x 1/4" and weighs 1.02 pounds/foot)
pic: 1726 Overdrive Chassis CAD GUI Extra Discussion 10 23-01-2008 00:07
pic: 1726 Promobot GUI Extra Discussion 18 01-11-2007 18:04
pic: Homestead Robotics Team Track Boxes Fully Assembled foundbobby Robot Showcase 8 20-02-2007 02:05
pic: Team 369: Arm Assembled Gabriel Mendez Robot Showcase 5 12-02-2007 22:12
pic: Team 1726 MegaMaid Motors/Chassis/electronic board yodameister Robot Showcase 3 11-02-2006 01:21
